shimming less than 0.0004" - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 78 of 78
  1. #61
    Dec 2008
    New York
    10,339
    2681
    Default picture
    only picture i got of tang slide part. close up because was having a mill pass lap problem at the bottom of a bore using a 18" long tool holder.
    as you can see the parts i mill are not simple cube shapes
    still not sure why the lap problem. possibly the long tool holder milling harder metal was vibrating more than normal. kind of hard to get a 1.75" dia mill sticking 18" out of spindle to cut extra accurate
    Attached Thumbnails Attached Thumbnails bn_problem_after1st_finish_2015_b.jpg
  2. #62
    Oct 2013
    Rochester, NY, USA
    119
    45
    Wait a minute! Am I the only one to notice numerous suggestions to shim with unstable things?
    paper
    plastic
    paint
    crayon
    embossed/wrinkled shim stock
    Even variable torque (bolts tend to relax with time)
    All these things will move in time; nice flat metal shims is the way to go!
  3. #63
    Dec 2008
    New York
    10,339
    2681
    Quote Originally Posted by greif1 View Post
    paper
    plastic
    paint
    crayon
    thats why i will order the 0.03mm steel shim .0012" in 1/2" wide rolls. it is the most stable and a difference of a .001" shim on one end of a part and a .0012" at the other end of a part is .0002"
    ....... and both will go in a gap with my body flat on a table reaching in my arm a few feet much easier than a flimsy shim thinner than .001"......... onion skin or plastic shims of only .0004" thickness are difficult to work with, fold over too easy putting in a 0.1" gap
  4. #64
    Sep 2006
    SE PA, Philly
    5,516
    1070
    1976
    You could shellac the onion skin between two shims, and shellac another two identical shims together w/o onion skin.
    I wonder if you could take a 0.005 or a 0.010 shim and put a kink in it. It would than give a slightly different height than an unkinked shim. Would this work?
  5. #65
    Dec 2008
    New York
    10,339
    2681
    Quote Originally Posted by bosleyjr View Post
    easiest and most reliable is for me to order a roll of 0.03mm steel shim stock.
    a lot of things could work, might work for the time it takes to do the job, but i can cut a 0.03mm shim in 2 seconds so thats the fastest once i have a roll of it
  6. #66
    Dec 2008
    New York
    10,339
    2681
    Default another picture
    another picture of part i was shimming with 6" dia face mill shown after rough machining
    fixture holds part in 3 different orientation for 3 different operations.
    part resting on 3 pads on ends that i shimmed. normally pads are not all the way on the ends of a part but spaced 0.7 apart of the part length to lower sag amount from gravity
    there is nothing currently under part center. it warped curve shape up in center (opposite gravity sag) after a machining operation on the part bottom. what was once flat was no longer flat or planer
    i ordered a roll of 0.03mm feeler gage shim stock which with .001 and .0015" shims gives a .0002 and .0003" elevation difference
    Attached Thumbnails Attached Thumbnails 210_tangslidehobheadcomponent_2ndop_3b_closeup.jpg   210_tangslidehobheadcomponent_2ndop_3b_smaller.jpg
  7. #67
    Jan 2015
    Tennessee
    36
    20
    19
    I thought I was a machinist.
  8. #68
    Mar 2012
    Florida
    418
    1293
    159
    Sorry to dig up an old post.... At an older shop I use to use onion paper with great success. I cant find anywhere what I use to use. We had a roll of it about 1 inch wide. Anyone have a vendor for this?
  9. #69
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4259
    I think the roast beef at Arby's is a little thinner than that.
    Zig Zags are about .0005
  10. #70
    Mar 2012
    Florida
    418
    1293
    159
    The zig zags work ok, are too small size wise and I don't like the creases in them. I also found that when you put a thin film of light oil on the part the shims stay in place pretty well before you clamp it down.
  11. #71
    Sep 2004
    south SF Bay area, California
    2,063
    158
    685
    I've never been a fan of thin shims, especially if they are made of a soft material. What has worked best for me are square-washer-shaped spacers of ground flat stock 3/8 inch to 1/2 inch thick. Match-grind to thickness if needed, install, and determine which spacers are too thick, and by how much. From that point, it's a metter of removing the oversize spacer(s), thinning it (them) as necessary, and reinstalling.
    If I recall correctly -- it's been quite a few years since I was the hands-on workerbee -- it takes roughly 100 feet of firm-pressure stroking on kerosene-wetted 240-grit wet-or-dry to thin a spacer 0.001 inch.
  12. #72
    Jan 2019
    86
    52
    42
    A human sperm is about .0002 diameter....I would just stack two of those and call it a day.
  13. #73
    Mar 2012
    Florida
    418
    1293
    159
    You must be quite the tool maker
  14. #74
    Jun 2012
    Michigan
    11,629
    3974
    4137
    .001 and .0015 and .0005 are so difficult to use and keep nice it would seem a manufacture would/could make .020 .0201. .0202 and on up to .021. in a set (and a metric set) 1/2" or 1" wide that could be purchased as a catalog item. Likely it could be a low priced set.
    I used to make my own back when doing fancy grinding, along with catalog .005, .010 .015 (and up) with these in different length so easier to identify, I also would mark them with the side of a Dremal point so having a marking that would not distort (like an electric etcher)
    Agree SS is/can be a bugger to grind
  15. #75
    Jan 2007
    Norfolk, UK
    19,852
    15289
    15563
    ''shimming less than 0.0004" ''
    Use a smaller hammer.
  16. #76
    Oct 2019
    NICARAGUA
    106
    41
    Sounds like a place i worked. A guy comes up and asks for some banding. I give him a piece i have handy. He says no, i need some of that thicker banding. Glad i dont work there anymore. And yes, they did it that way for 40 years, and probably still do.
  17. #77
    Mar 2012
    Florida
    418
    1293
    159
    Shimming a large block on a magnet does not work with thicker shims, If it was clamped to a angle iron or something that is a different story.
  18. #78
    Jun 2012
    Michigan
    11,629
    3974
    4137
    QT:[i am just asking, does anybody have a better way of shimming heavy castings of less than
    a .0004" ]
    I don't have any better way..than map it on the plate if that is where it will be inspected.. and then find the the tested amount (of needed take) at the position where it will be machined or ground. looks like that is what you are doing...
