Shizouka an-s
pat pounden
Cast Iron
Jul 4, 2019
Shizuoka an-s
good morn to all-pat here,still bumbling around w/ my shizuoka vari drive--i have taken the 'top off' of my shiz,to replace every bearing up there purely as a maint. item -thought i heard a little noise--everything has been pretty easy til now-have enclosed pics,even if they are tilted-but these sheaves here have got me!-one is pressed on the shaft,next to the drive tang part,and the other is the sliding one i can't get the sliding one off the shaft;there are/were little plastic'keys' for lack of the right term that are visible through slots-at least one of them covered a set screw going into the shaft-but it won't turn in or out enough threads to make a difference-maybe one 180 opposite,but haven't destroyed the plastic enough to expose it--didn't set out to destroy ANYTHING but have to figure this out 'reversely' somehow-sorry for the ramble--ANYONE here w/ experience on this exact part(s)-maybe an ex shiz tech?? thanks in advance for any help!!--pat,in norcal
The place in Japan that probably gave its name to your machine is Shizuoka, not shizouka. Correct spelling in thread titles helps the search function to work for future reference.
Larry
-does it look ok after the edit-i see a cap 's'- still,this is not exactly the help i'm looking for--any Shizouka people around w/ some ideas?-thanks,pat
You keep asking for information on a non-existent brand. Correct spelling might get you in touch with an owner of a Shizuoka machine.
Search engines work best with correct spelling of your key word, so you might try Google.
Larry
thank you!-thought it was just the capitalization-never paid attn to it!!-just spent 10 mins trying to delete-will let me edit but won't delete!!
hope this helps,but will try starting a new thread w/ same,correct spelling post tomorrow if no re's -thank you again--pat
