SHop made Tapping Head
Likes Likes:  0
Results 1 to 9 of 9
    Apr 2009
    CA USA
    179
    28
    16
    Default SHop made Tapping Head
    Have any of you folks made your own tapping head ? Anyone know of any plans for one ?
    thanks
    animal
    Oct 2005
    22,567
    Quote Originally Posted by animal12 View Post
    thanks
    animal
    Your question would be better served at the Homeshop machinist forums.
    Sep 2006
    Stillwater, Oklahoma
    1,893
    150
    1124
    If you're talking about something that just holds a tap vertically, yes I've seen plans for more than one.
    If you're talking about reversing heads, then no, I've never seen plans for a DIY. That's a level of detail and precision best left to manufacturers with experience.
    Feb 2010
    ch
    3,383
    280
    472
    How to make a torque limiting tap head
    look on youtube as well.
    Oct 2010
    Oregon
    5,818
    5788
    2248
    Actually, the Hardinge TT releasing tap head (for turret lathes with reversing spindles) would not be a hard shop project.
    If you had a source for an appropriately sized planetary gear set, you could reproduce a Procunier E-style reversing tap head (for drill presses withough reversing spindles) without too much difficulty, too. But that would require a much wider range of operations (forming the shell, making a cork-lined clutch cone, etc).
    Feb 2009
    Colchester UK (where the lathes used to be made)
    2,127
    1559
    688
    I designed one, but never got around to building it.
    https://www.madmodder.net/index.php?...ch=29345;image
    tapping head.jpg - Google Drive
    Apr 2009
    CA USA
    179
    28
    16
    Thanks folks , think I'll spend some time looking into those clutches mentioned .
    thanks
    animal
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,497
    4390
    4108
    The reversing gear does not even have to be planetary.
    I've got an old 1/2" (at least) tap capacity, factory made unit that is sloppy as heck after a century of use. It does not have a friction clutch, just a cross-pin dog clutch. Moves the gear up or down when you lift or apply down pressure to the machine quill. The reversing gear is offset to one side.
    smt
    Feb 2010
    ch
    3,383
    280
    472
    i find a tapping head not so usefull, btw. i use a set of "tapping inserts", one for every size and the mill does the reversing. i can really rely on the torque setting without having to mess with it. i regularly tap full power into a blind hole.
