Shop Made Tool pics - Page 6
Page 6 of 19 FirstFirst ... 4567816 ... LastLast
Results 101 to 120 of 363
  1. #101
    Feb 2007
    Cucamonga, Ca. USA
    239
    12
    I built this sander a few years ago because i was to cheap to buy a BURR King.
  2. #102
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,970
    1370
    588
    Default Low profile coax indicator
    My Haighton is a bit short on room between the vertical head and the bed (Hardinge TM UM owners will know what I mean) so I built this low profile coax indicator specially for it. (see madmodders)
  3. Likes crashtestdummy liked this post
  4. #103
    Oct 2010
    Tucson, Arizona, USA
    Quote Originally Posted by gregg-k View Post
    If the tang slot is rounded out, I wouldn't be surprised if the taper is buggered as well ? Otherwise, if the taper is good, why worry about the tang slot ?
    .. Gregg
    I checked it and there are a few small grooves but it isn't nearly as buggered as the tang slot. Probably with some emery paper and oil on a bit I can hone it back to new. Problem is that drilling when there is some chatter vibrates the bit loose and without a tang it slips out. Do you think the set screws is the wrong way to go?
  5. #104
    Feb 2007
    Virginia
    149
    8
    9
    Default Dremel tool cut off adapter
    I thought I would post a picture of my "ghetto" Dremel too cut off attachment for my quick change post. I have to make 100's of little 3/8" long tubes from seamless brake lines for our work, and this system allowed me to use the DRO for measuring and the cross feed for the cutting direction. Works very well. I also made a similar attachment for my Mill, as well. Goes in a 3/4" collect.
    Cismontguy
  6. Likes crashtestdummy liked this post
  7. #105
    Jun 2006
    New Jersey
    3,115
    341
    280
    Quote Originally Posted by gr8life View Post
    Some really gr8 stuff here. Here are some pix of a cut knurling tool I built from plans in "the other site's" magazine.
    gr8job. Hard to tell that from the one in the magazine. How long did it take you to make it? Did you make it to print or modify it? Where did you buy the cut knurls?
    -DU-
  8. #106
    Dec 2007
    Las Vegas Nevada
    284
    19
    Thanks David, I got them from KBC. I think I have 5 different tpi as I do a lot of knurling. Get the plans & make one, if I can anyone can. I think I must have made 1/2 of the parts 2 times.
    thanks
    ed
  9. #107
    Feb 2008
    Hawaii
    216
    5
    33
    Here's a little accessory I made to layout circles using my divider and a Sharpie.
  10. #108
    Dec 2007
    Las Vegas Nevada
    284
    19
    This is like playing show and tell, the pros on this site must be saying "wow I made that stuff when I was in training.
    Here is a toolpost mounted ball turner that I built a while ago. I recently redid it and have mounted a RNMG insert on the end of a tapered cone. This was a big change for the tool. Since most of it's use is to round the ends of shafts rather than making balls it cuts better & puts all the pressure on the cone which is larger on the side that takes all the pressure.
    more next reply
  11. #109
    Dec 2007
    Las Vegas Nevada
    284
    19
    The 2 knurled brass caps are oil ports & are threaded in.
  12. Likes extropic, crashtestdummy, zoeper, almarghi liked this post
  13. #110
    Jul 2004
    Vicksburg, MS
    4,931
    30
    259
    Hey gr8life, that is a great idea, fine work! I haven't see that before.
  14. #111
    Feb 2009
    1,970
    1370
    588
    Default Height gauge
    You won't know how handy it is until you've made one...
    Simple length of tube turned and faced with grooves to set tool height.
    Attached Thumbnails Attached Thumbnails height-gauge-1.jpg   height-gauge-2.jpg   height-gauge-3.jpg
  15. #112
    Mar 2009
    Brunswick Oh USA
    4,586
    5192
    2729
    Bill,
    That should simply not be allowed! Makes to much sense and to easy to make. I for one will refuse to make one..........today.
  16. Likes Curious Yellow, extropic liked this post
  17. #113
    Feb 2009
    1,970
    1370
    588
    Quote Originally Posted by Ray Behner View Post
    Bill,
    Sadly, I can't claim it as my idea. One guy (Bodstandard) came up with the idea of using a turned and faced piece as a simple square, and another guy (Jon-Som) suggested scribing a line on it to mark the tool height.
    Bill
  18. Likes Cleftwynd liked this post
  19. #114
    Aug 2006
    New Zealand
    1,299
    78
    275
    Hello
    On a similar line to the grooved turned tube (far too simple, logical and easy), see here for my version (satisfyingly complicated).
    Denford Software & Machines • View topic - Yet another tool height gauge design
    This is my un-made shop made tool.
    Dazz
  20. #115
    Mar 2001
    New Haven, CT
    3,520
    44
    690
    Can't say it is a shop made tool but a little trick I have found that gets the tool on center is to stick a 6" scale between the tool and the work piece. When the scale stands vertical it is on center. Usually this gets it good enough.
  21. #116
    Jan 2009
    S FL
    880
    239
    210
    Quote Originally Posted by Empireweld View Post
    Is that mother stainless??? If so, how many cutters did you burn through. nice job!
  22. #117
    Jun 2008
    Bellingham, WA
    4,117
    989
    2256
    Quote Originally Posted by Billtodd View Post
    I have been using a similar device for a few months in my shop. I first used a groove to set the tool height but later found it to be a little easier to get the tool set at just the right height if the tube is faced off at the set height. Then you can use your finger to feel if the tool is right on or a tad low or high. But either set up is miles ahead of any other method I have used.
    Mine is not quite as shiny though
    Denis
  23. #118
    Feb 2007
    Cucamonga, Ca. USA
    239
    12
    No not stainless, I just wanted the paint to stick. It weighs about 300 lbs and has 5hp motor and loves knuckles.
  24. #119
    Dec 2001
    Middleton,WI USA
    489
    5
    Default Center tool
    This is what i made it it is primitive but seems to work,,, took a minute to make.
    Cheers
    mac,,,
  25. Likes crashtestdummy liked this post
  26. #120
    Nov 2010
    Dunlap Iowa USA
    16
    Default Drill Vise
    I know this isnt as pretty as some of these but it works great and was completely hand made by welding scrap stuff from around the shop. My first Machine Tool if you will
    Capacity is 4 inches wide by 3 15/16 inches open.....
    Thanx Corey J Ne
  27. Likes James Kain, crashtestdummy liked this post
