Shop Made Tool pics - Page 7
Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 363
  1. #121
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,948
    1348
    567
    Default Small English Wheel
    Here's a small English wheel that my brother built.
    The rollers are made from the centres of industrial neoprene tyred wheels with the tread removed.
    Attached Thumbnails Attached Thumbnails small-english-wheel-1.jpg   small-english-wheel-2.jpg
  2. Likes crashtestdummy liked this post
  3. #122
    Feb 2009
    1,948
    1348
    567
    Default Miniature English Wheel
    Here's a miniature English wheel that my brother built.
    The rollers are simply two ball races with the lower one shaped on a grinder and polished.
    Attached Thumbnails Attached Thumbnails mini-english-wheel-1.jpg   mini-english-wheel-2.jpg   mini-english-wheel-3.jpg
  4. Likes James Kain, crashtestdummy liked this post
  5. #123
    Dec 2004
    Central IL, USA
    1,181
    56
    105
    Quote Originally Posted by Billtodd View Post
    You won't know how handy it is until you've made one...
    Simple length of tube turned and faced with grooves to set tool height.
    Bill,
    It's simply too elegant and will take all the fun out of dialing in tool heights!
    Oh hell with it, I'm gonna make one too!
    I'm still making hammers, I have another group of 20 in the works now which should bring me to around serial number 50!
  6. #124
    Jun 2009
    PA- USA
    107
    For centering up tool bits on the lathe, I use these. Have made and sold bunches of them and they work pretty well on any lathe. No need to make something separate for each lathe.
    Hereis an arbor made to fit my Clausing 8540 horizontal mill. Could have bought one hardened and ground from China for $25 but, I spent the time making it anyway. NMTB 30
  7. Likes crashtestdummy liked this post
  8. #125
    May 2009
    Pasadena TX
    12
    12
    Why did this thread stop?? I'm a 30 year machinist but everything I made for myself looks like a cave man made it lol. This is great stuff y'all....so don't stop posting pics!
  9. Likes Bobw liked this post
  10. #126
    Aug 2006
    New Zealand
    1,257
    75
    252
    My Haighton is a bit short on room between the vertical head and the bed (Hardinge TM UM owners will know what I mean) so I built this low profile coax indicator specially for it. (see madmodders)
    Nice work.
    I followed the link to the discussions on magnetic pickups.
    I suggest looking a linear variable differential transformer (LVDT)
    They are cheap, accurate and easy to apply.
    see here: Linear variable differential transformer - Wikipedia, the free encyclopedia
    for explanation.
    I would mount a LVDT up the centre of the arbor. I would have a sleeve with a crank pivoted on the lower edge.
    Wobble and runout could be reduced by using a pair of preloaded bearings rather than a sliding fit (which must always have clearance between the surfaces).
    Attached is a concept sketch. A lot of work would be needed to convert this to a proper design.
    The advantages are that a very short gauge could be made, especially if the bearings are mounted back to back (not as drawn). The LVDT can go right up the centre of the arbor so wouldn't add to the length.
    The disadvantages are that the unit would need a cable to a separate display, power supply and controller. Of course, it would be possible to squeeze all of this into the gauge with custom electronics.
  11. #127
    Oct 2004
    St. Peters, MO
    2,972
    157
    140
    I made a radius turing tool for my Nardini a couple years back. Uses a machined hub and tapered spindle bearings. It is adjustable up and down but the base assembly mounts specifically to my Nardini's Compound t-slot.
    I "Blued" it as well which is why it is the color it is.
    The second 2 pics are of another cutter that uses a small carbide insert to cut radii much smaller 1" and up. I use this tool for making tube bending dies. It fits on my bxa QCTP.
    Grant
    Attached Thumbnails Attached Thumbnails radius-ball-cutter.jpg   radius-ball-cutter-2.jpg   die5.jpg   radius-tool-convex.jpg
  12. Likes James Kain, crashtestdummy liked this post
  13. #128
    Oct 2007
    detroit,mich.
    4,704
    4710
    418
    Quote Originally Posted by Cranky1 View Post
    but everything I made for myself looks like a cave man made it lol. !
    You and me both! LOL!
    Mostly because of lack of time.
    Jeff
  14. Likes James Kain liked this post
  15. #129
    Feb 2011
    Pensacola, FL
    1,308
    154
    810
    I really enjoyed reading through all the previous posts and viewing the pictures of all the cool shop-made tools. Some are very enspiring to me, and wish I had the time to make them myself.
    Over the years I am constantly thinking of tools I should make for myself to use on the machines, but I just never really have the time to spend on my own projects. I can say that Ive made many usefull custom tools for cutters and taps over the years, but mainly because what I needed wasnt readily availible. Ive also made countless jigs and fixtures for doing specific jobs, but Im sure thats wth any shop, and I dont think I have any pictures of them.
    I have found several home-made tools in some of my tool boxes also, but made by previous machinists that we acquired over the years.
    I have been planning on building my very own welding turntable one day using a 36" faceplate thats been sitting in the corner for decades. My first thoughts were to make it free spinning, but I would now like to build it with a variable speed system.... if I can round up the right parts at Motion.
    As mentioned before, I just dont have anough free time to build all the projects and custom tools that Im constantly thinking of. But seeing some of what other have made gives me more motivation to use what free time I have to spend on my own ideas.
    This is something I did design and build myself though. I wanted a shelf next to my mill to hold the Kurt vise and 8" superspacer that would swing out of the way when not in use. Although Im a big guy, I get tired of picking up that heavy equipent everyday!
  16. #130
    Apr 2008
    Northern VA
    318
    Great idea! Here is a quick idea to add to your design.
    If you used the base/column of a cheap floor-based drill press to hold your shelves, you could use the crank from the drill table to raise and lower the shelves to the appropriate height so you can just slide the heavy stuff from the appropriate shelf to the mill table without lifting!
  17. #131
    Feb 2009
    1,948
    1348
    567
    Quote Originally Posted by biometrics View Post
    I'm betting he has a power feed on his knee, that allows him to raise and lower it to the tool shelves
  18. #132
    Feb 2009
    1,948
    1348
    567
    for explanation.
    Neat idea.
    RE: your drawing. Are you proposing to keep the spindle and arbour still and revolve the head by hand? Because, if you could arrange for the probe to turn with the spindle while keeping the cables still then it would be possible to resolve the X and Y axes to two displays thus making the adjustment much easier.
    In fact if you had a wireless head unit (Infra-red perhaps)that could detect a reference point on the mill it could transmit X and Y offsets to a remote display (how neat would that be !)
    Bill
  19. #133
    Feb 2009
    1,948
    1348
    567
    Snap!
    (Although yours are much better made )
  20. Likes James Kain liked this post
  21. #134
    Feb 2007
    Kansas
    523
    137
    167
    Steady rest I made years ago.
  22. #135
    Feb 2011
    Pensacola, FL
    1,308
    154
    810
    As Billtodd said, the mill does have the Servo on the knee so its quick and easy to line up the shelf and slide the tools off. Its nothing fancy, just materials I already had in the shop.
  23. #136
    Feb 2011
    Pensacola, FL
    1,308
    154
    810
    Quote Originally Posted by J.Ramsey View Post
    That is exactly what I need to do for my 21x120 Acra-Turn lathe. It only came with a 6" capacity s/r and I need one larger. I called Acra recently and I can buy a 10" for around 700, or a 12" for aboout $900. I should just save my money and build one like you did.
  24. #137
    Aug 2006
    New Zealand
    1,257
    75
    252
    Neat idea.
    Bill
    The intention was to keep the spindle / arbor still (avoiding the problem of cables wrapping around the arbor) and rotating the outer sleeve by hand. The LVDT and arbor remain stationary.
    I understand that the need for wires and a (small) power supply, display etc will not appeal to many members.
    It would be entirely feasible to get rid of the wires and replace with a Bluetooth wireless link. Batteries and everything could fit within the arbor. This could then display readings on another Bluetooth device (eg. mobile phone, Ipad). How cool would that be.
  25. #138
    Oct 2009
    Louisville, KY, USA
    970
    214
    217
    Shop-MADE tools thread. Post a pic or start another thread.
    Mostly 'cause I don't understand all that techy stuff.
  26. #139
    Jan 2008
    New Hampshire
    242
    74
    65
    Default Welding Positioner
    Here's my positioner made from an old rotary table, 12" 3-jaw chuck, and a 90vdc variable gear motor......
    angles all positions from horz to vert....fork pockets for vari height....
  27. #140
    Mar 2005
    Houston
    516
    70
    Default Hammers
    There have been a multitude of very nice looking hammers but all are with round cross section handles. Round handles are difficult to control.
    JRW
