1dogandnoexes
- Jan 20, 2019
I've turned some bearings from 841 bronze from McMaster-Carr for a non-precision application. The largest part of the outside diameter is 3/4", 9/16" long overall and turned into the shape of a flanged bearing, which are in turn, then pressed into its mount. The bearings have a 7/16" diameter through hole, which I've been drilling with a drill bit held in a Jacobs chuck in a lathe tailstock. The tip of the drill bit is more than 4" past the fingers of the chuck and even further from the point at which the chuck's shaft is supported by the lathe's tailstock. So there's lots of opportunity to lever the drill bit. The chucked work piece is pulling the bit off of the axis of rotation, despite having used a center cutter to establish the center, and a pilot hole, which hole suffers from the same problem. I don't have a lathe boring bar that small, and don't have what I need to hold the work piece on the mill.
I need to make 6 more bearings and I'd like to be able to make them quickly, easily, and accurately without the off axis Macarena of the cutter.
If anyone has purchased an index of very short drill bits in 1/64" increments or knows where to source very short bits or end mills, please let me know. Or do I just plan on cutting an end mill? (which is probably going to be a PITA.)
Thanks in advance
Thanks in advance
