shrink fit sleeve for stripped main stud - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Mar 2006
    PHILIPPINES
    2,364
    485
    699
    Are you sure about that 90lbs torque spec? The handbook maxes out at 70 for grade 12.9 studs.
  2. #22
    Oct 2009
    Oregon
    4,092
    4388
    2056
    Quote Originally Posted by g-coder05 View Post
    ARP uses magic metal.
    Pretty common to overtorque ARP headstuds 180% and they don't stretch a bit.
  3. #23
    Mar 2006
    PHILIPPINES
    2,364
    485
    699
    Pretty sure the torque is way off. heres a old post here with the specs for Studs in Aluminum...
    torque for screws in aluminum engine block
  4. #24
    Feb 2005
    9,018
    13662
    10663
    Here is the page for only main studs ARP has for a Hyudai.
    Click instructions to get the PDF, 1x1.25 and 70 ft/lbs.
    Which seems REALLY high to me for the size of stud and the fact
    that the block is aluminum..
  5. #25
    Feb 2004
    peekskill, NY
    24,229
    4417
    Correct torque value not withstanding, suggest:
    1) drill and tap the location for an M12 thread. Coarse probably better.
    2) manufacture a steel OD/ID threaded sleeve to match the threads involved. Simple 1018
    should work fine. Install by putting your stud into it, and locking it on there with a
    nut jammed in place.
    3) use green locktite when installing. (remove installation stud before
    lockite sets up!) If *that* pulls out then you were in deep trouble at
    that location in the original casting.
  6. #26
    Sep 2019
    New Jersey
    5
    i may be mixing up the torque values in my post since im not looking at the papers but 70lbs sounds about right. maybe the head studs were 90 and i was thinking of that. ill give the m12 thing a try and if that doesnt work then i guess im gonna have to cut this thing spart 🙃 thanks for all the quick replies, really never had such a positive first experience on a forum before.
  7. #27
    Aug 2005
    Tucson AZ
    6,276
    9377
    2939
    Quote Originally Posted by jim rozen View Post
    You didn't read the thread , did you? If you had you would know that the wall thickness he has left is slightly more than heavy aluminum foil. He doesn't have enough for a 12mm thread and never did.
    OP, regardless of how magic the ARP studs are, you are still screwing them into a Hyundai. Forget what they say, their numbers were probably high for cast iron. Read g coders link and be aware that those numbers are high. If you are trying something with a Hyundai engine that requires such studs then you are fooling yourself.
    Y
  8. Likes AlfaGTA liked this post
