The shaft is indeed a lead screw (still in machine so no exact measurements yet) and is 1/2" X 10TPI and about 3' long. About 4" on each end is not threaded and then at the very end about 1/2" has threads for the hand wheel. Entire length has a 1/8 wide key way. So again I know how to single point but never have done acme. I looked at McMaster and they have precision threaded rod but will still need to make the correct ends and weld or pin to the threaded part. So I think I am better off just making it from scratch. After that I need to make the acme nuts but that is easy with a tap.
Three feet of skinny 1/2" steel, an Acme formed, high-drag Carbide insert, not even a skinny HSS shearing-action nibble-luncheon to gradually "generate" the shape, and your first, ever, go at single-pointing this
thread-form, on a 1970's vintage Taiwanese Victor 1640G that two years ago was giving you grief as to surface-finish on SHORT 5/8" conventional threads??
"Better off" just how?
The Acme is more likely to
make YOU nuts than the other way 'round!
No extra pay for demonstrating you can stand a beating. Perhaps after wasting more than one go at it, yah?
Have somone running a video so you have a record of just how long, skinney s**t goes pear-shaped right about 18 inches in as the
de facto if not also
de jure noodle climbs right up over the top of the cutting tool and starts to squirm atop it like an Earthworm in a puddle of gasoline. DAMHIKT, either.
I'd buy it, then modify it.
Needs a keyway? I'd ORDER it that way as well. Three-foot run, half-inch stock, dead-nuts aligned, is a lot to ask off an old BirdPort mill and wotever you have for workholding.
My Quartet's 48" overall, 42" "working" inside the cutting-oil gutters table only HAS 30" of traverse, can put EITHER of a horizontal or vertical head over it. I get a wild hare, I can line-up FIVE 6" Gerardi modulars on it, too. Drawerful of Vee-blocks, clamps, etc.
Still not good enough for 36" in one go.
A BirdPort may have a 42" table. But does it have 36" of travel? With no table sag or deviation along it? One of those is not there.
Do only the bits one CANNOT "just buy". Challenging enough as it is, those are.
