Well I have owned and been around those machines and never saw one using plain water. Either soluble oil or some light oil and yes ATF. Plain water and you will soon have a rusty lump.
40 years ago I was using a Kwik-Way valve grinder and the sump of that machine was filled with grinding oil.
1 Gallon (3.8L) Valve Grinding Oil [000-2112-73] : Kwik-Way Online Store, A Tradition of Automotive Precision Since 1920
My boss would've shot someone if they filled the sump with water.
Rex
Gee 40 years ago I was using one of those machines refacing valves and was using some form of oil,come to think about it I was doing it right at 50 years ago at my first job in the automotive after market !!I was using a Sioux valve grinder forty years ago. What were you doing forty years ago?
Don't use oil. You are grinding. That's abrasion. Oil is for lubrication. Why would you want to lubricate a grinding wheel? Oil interferes with the abrasion.
Use water.
so you've been doing it wrong all your life because someone taught you wrong. I know that mechanics commonly use oil in a valve grinder, but that doesn't make it right. I've seen the work turned out on a valve grinder using oil, and it looks bad. Not nearly as good as when water is used.
Rex
When you go to the electric grinder to sharpen a drill bit, do you put oil on it? When you use an angle grinder to grind a weld, do you put oil on it? Do you put oil on anything else to grind it, besides a valve?
Well now that is done can we get back to the pump. I was thinking about the little giant myself but has anyone tries anything else besides that.
Notice
