Slicing vulcanized hockey pucks (duro 90) into coasters - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21
    Mar 2009
    Eureka, CA
    3,611
    686
    1185
    1200 degrees Fahrenheit? That's one heck of a simulator!
    Stuart
  2. #22
    May 2011
    New Jersey
    1,597
    148
    836
    Quote Originally Posted by atomarc View Post
    Stuart
    Yeah it's basically to simulate worst case scenario. I remember one time we were in for so long, about 5 minutes, maybe a little less, the the air in my Scott cylinder got so hot it was burning my throat breathing and my gear got super tight lol. It's not uncommon for things to melt.
  3. #23
    Feb 2011
    1,853
    1115
    766
    Anytime we cut rubber on the lathe, we'll first freeze it in the break-room kitchen freezer, or in some dry-ice for fine feature/troublesome parts. Baby powder for lube.
    Now, in terms to slicing rubber: We build/service machines for thinning down heavy textiles called band-knife splitters. Works just like a horizontal band saw, but with a knife edge and precision feed guides and rolls to guide the material across the blade horizontally and split it to a desired thickness (down to .6 mm and occasionally thinner).
    While designed primarily for dry goods like leather, they are also often used to split rubber goods. To do so they are fitted with an attachment that drips oil on the tip of the blade (in addition to the lubricant normally coating the body of the blade).
    Now I doubt the OP wants to buy heavy equipment for a quick job, but I'd start with the principals these splitters use:
    -ridiculously sharp and moving knife that the work is moved across
    -oil for lubricant
    You can buy knife blades for band saws. Not sure about the sharpening bit. I think they are changed out when dull, while on a band-knife splitter the machine has a built in sharpener that will often be in use while you are splitting material (gets dull faster than you'd think). But for a quick job on the band-saw, a new knife might be all you need.
  4. Likes Dumpster_diving liked this post
  5. #24
    May 2017
    Massachusetts
    200
    130
    92
    Naegle's production-oriented solution is quite interesting. A cheaper one-off method might involve an electric upholstery knife. Basically a reciprocating very sharp knife blade on a base that can be run over a flat table. Don't think you'd get more than a dozen cuts before dulling the blade. But similar concept.
  6. Likes M.B. Naegle liked this post
  7. #25
    Nov 2018
    Michigan
    131
    54
    68
    Quote Originally Posted by M.B. Naegle View Post
    Can confirm. I recently needed to cut some square rings (.275 cross-section) on the lathe, "part-off" style. The x-acto knife looked a little silly sitting in a CA toolholder, but it did the job, losing about 0.005 - 0.010 off its tip each time it went through a ring. If I had any more than 6 to do, I'd have used the spare blade I brought with me to do the job.
    Edit to add: Diameter ~7" and speed was 300 RPM or so (250 sfm). Feed worked nicely at the lathe minimum of 0.0026" per rev diametrically, so I didn't go any faster. 70 durometer NBR. With a band saw blade, you have a lot more blade in the cut so friction is going to be a bigger factor for you.
  8. #26
    Sep 2009
    barcelona, spain
    2,188
    498
    1330
    Sounds like an impossible job, commercially.
  9. #27
    Jun 2008
    Roanoke, VA
    625
    182
    218
    Why can't you use sheet if you're looking for thin round disks? Sounds a lot more practical than slicing hockey pucks, assuming that is what you're actually proposing to do.
  10. Likes M.B. Naegle liked this post
  11. #28
    Mar 2009
    Eureka, CA
    3,611
    686
    1185
    Gotta be the real deal Dude!
    Hockey in the cards – Red Deer Advocate
    Stuart
  12. #29
    Mar 2014
    Michigan
    407
    77
    213
    I can't believe there is no 'hold my beer' youtube video of some smashed guy slicing a hockey puck on a commercial meat slicer.
  13. #30
    Feb 2011
    1,853
    1115
    766
    Quote Originally Posted by Nmbmxer View Post
    That's what 99% of rubber products makers will do. Use a sheet made to the thickness you want and die-cut the outer peripherals. The other 1% is often cutting finished pieces down for testing, or odd-job work.
  14. #31
    Dec 2007
    Central Ohio USA
    3,720
    64
    1678
    Hunt down the mfg's of these:
    https://www.ebay.com/p/Washington-Ca...d=292533707394
    Or Google up 'sliced hockey puck coasters' for a large number of offers. Tracking down their manufacturers will yield some info or possibly suppliers.
  15. #32
    Jun 2012
    Michigan
    9,250
    3142
    3324
    I wonder if on a lathe one might use a fixtured brand new fine tooth hack saw blade and slow turned the part(puck)perhaps 300 rpm running wet might work. Yes the saw mounted in the hack saw frame would not move but just swing down into the part.
    Perhaps the saw frame weighted one pound or so,, what pressure to cut but not stick.
    Perhaps the part in a 3 or 4 jaw chuck.
    Perhaps hand finish with flat lapping on auto wet paper.
