crossthread
Titanium
- Aug 5, 2004
- Richmond,VA,USA
We have a part that is going to be exported. Part of the assembly is 12L14 stock which is 0.15 to 0.35% lead. If I understand the restrictions stated below correctly then the part can't be made with this material. Have any of you come up against the ROHS issue in manufacturing and how did you deal with it? Thanks.
"The maximum permitted concentrations in non-exempt products are 0.1% or 1000 ppm (except for cadmium, which is limited to 0.01% or 100 ppm) by weight. The restrictions are on each homogeneous material in the product, which means that the limits do not apply to the weight of the finished product, or even to a component, but to any single substance that could (theoretically) be separated mechanically—for example, the sheath on a cable or the tinning on a component lead.
As an example, a radio is composed of a case, screws, washers, a circuit board, speakers, etc. The screws, washers, and case may each be made of homogenous materials, but the other components comprise multiple sub-components of many different types of material. For instance, a circuit board is composed of a bare PCB, ICs, resistors, capacitors, switches, etc. A switch is composed of a case, a lever, a spring, contacts, pins, etc., each of which may be made of different materials. A contact might be composed of a copper strip with a surface coating. A speaker is composed of a permanent magnet, copper wire, paper, etc.
Everything that can be identified as a homogeneous material must meet the limit. So if it turns out that the case was made of plastic with 2,300 ppm (0.23%) PBB used as a flame retardant, then the entire radio would fail the requirements of the directive."
