UptownSport
Cast Iron
- Jul 25, 2012
- Cable WI
I need advice on a piece of CI to space up a vice, and just how sound this idea is.
I need to slit ~halfway a 5/8 6061 screw with a 1.125 head. I no longer have access to the Bridgeport, so I'm considering using one of the old lathes- Think Sheldon. I would use the cross to feed the vised piece into the cutter- Jaws parallel to cutter.
I read relevant parts of Tubal Cain's 'Milling in the Lathe' and think I understand. I need to make an arbor- I think that's straightforward enough- for use in a MT spindle collet.
My thought was to space with a $84.38 piece of CI from McMaster.
McMaster-Carr
Is this how much CI costs?
There's details such as how I'm going tighten an arbor without a flats (no Bridgeport now, either), vise/tailstock clearance and length vs stability of the arbor. Then I'd be the newb taking a full cut with some wicked cutter...
I assume the CI finish is 'good enough' to use as a spacer.
How viable is the idea? I'm looking a few dozen pieces and thought it easier than a milling attachment.
Thanks as always
Clearances
Cross to spindle Ctr: 3.625
Spacer: .75 (Where the CI Piece Comes in)
Vise OA Hght: 2"
Arbor dia (1/2 of this value): .625
=.25 vise to arbor clearance
Slitter Cut:
Spacer: .75
Vise OA Hght: 2"
Slitter dia (1/2 of this value): 1.5"
= -.625 (Approx -.5625 needed) Head is 1.125 dia
Vise jaws should have enough depth to cut ~1/16" less than halfway.
Head (Half) 0.25
Screw (Half) 0.3125
0.5625
Diff from .625 0.0625
Screw (Half) 0.3125
0.9375
So, I'd have 1/16 of depths remaining.
McMaster-Carr
Thanks as always
