slitting saw going the wrong way
Results 1 to 6 of 6
    Feb 2010
    ch
    2,451
    212
    315
    Default slitting saw going the wrong way
    i just cut a slot in crs 20 mm long and 20 mm deep with a 4 mm hss saw. little horizontal sounded good, chips looked good. then the nut unscrewed and i realized i was running the saw the wrong way. when i changed direction the chips looked about the same. what are all those fancy angles for on the cutters? (maybe there is some magic to a swiss alesa saw?)
    edit: to be clear, the saw rotated the wrong way.
    Jan 2007
    Norfolk, UK
    19,664
    15106
    15264
    Dunno - I'm not that lucky.
  3. Likes Hopefuldave liked this post
    Mar 2017
    LATVIA
    512
    131
    259
    "fancy angles" have little to do with the "wrong way" in this case (which I'm guessing is feed direction, not tool rotation), general construction of the machine and the condition it is in will have an effect if the saw cut in climb or conventional way, but if it performed equally in both directions, then I'd say the machine is in decent condition
    Oct 2010
    Oregon
    5,291
    4743
    1939
    Tool rotation, jz79. "then the nut unscrewed".
    dian, I've no idea. I would have expected a huge squealing, a lot of feed pressure, way too much heat, and not a whole lot of chips. You can remove metal with a rock, so I can see where teeth running backwards might remove some metal, but I'd not expect normal looking chips.
    Mar 2017
    LATVIA
    512
    131
    259
    hmm, must have missed the nut coming loose part the first time I red this, or he added that later in edit, because I recall only "normal chips in the wrong direction", which is impossible in CRS with a slitting saw teeth running backwards, hence I concluded it was about feed direction - that would be the only way to get chips looking the same way while doing something "backwards"
    Apr 2012
    antelope ca
    16
    17
    just like running a lathe with a threaded spindle in reverse, the cutting pressure tends to loosen the thread
