Are there any reasons they would be anything but flat top?
dee
;-D
The Slitting Saw and the Woodruff Cutter
Slitting Saws and Woodruff Cutters work in much the same way, so we can just call them saws for now. Saws have one big difficulty. After we understand that difficulty we will solve it and increase their performance. First a little background.
After you dig a hole in the ground to fix a water pipe you need to put the dirt back. However all the dirt won’t go back because it doesn't fit any more. The dirt has been "upset". That is, all the little grains of soil and pebbles are no longer nestled together in a compact form. This upset condition also happens in metal during the cutting process.
Upsetting the metal increases its volume. So the metal in a chip that is cut from a bar takes up more space after it has been cut. Parting off steel in a lathe using a slender flat top “part off" tool creates a long slender upset chip. This chips volume is greater than when it was compact material in the parent metal. And greater also are its dimensions. The chip is longer, thicker, and wider. The wider condition is what causes the problem. The “Kerf” or groove being cut has a width as wide as the part off tool. During the cut, the emerging chip is actually wider than the groove being formed. So the chip is in the groove under a "press fit" condition. As the bar is rotated the press fit chip is being forced down against the cutting tool. The tool has to support the pressure of the downward cut in addition to the downward force created by the emerging chip. The deeper into the bar the tool cuts, the greater these forces multiply; because the chip grows longer before exiting the groove. The tool will break during this process unless the cut is shallow or the feed rate is very light. A light feed rate will create a very thin "ribbon" like chip with light forces; but this takes a much longer time to do the work.
The difference between a part off tool and a slitting saw is a slitting saw has many "part off tools" or teeth around its axis. Manufactures of these saws make them with tooth forms which have flat ends on the teeth like a part off tool. These teeth then cut a chip which is as wide as the slot just like the lathe tool and with the same problems of high destructive forces caused by the "press fit" chip being formed. Unlike the lathe tool the saw has many teeth. So if one tooth misses cutting something the tooth following right behind it can scoop up the remainder. Now for the "Fix".
A double cut saw blade has chamfers on alternate teeth. These chamfers on one corner of the tooth are made by grinding away one third of the tooth on the right side of the first tooth and then on the left side of the next tooth and so on. This grinding is done on each tooth at about a 45 degree angle. Now when the saw cuts, it cuts a chip on the left and then a chip on the right. These chips are only two thirds as wide as the slot. The following tooth has its chamfer on the other side and so it picks up the remainder of what the first tooth left. The forming chip isn't wide enough to rub both sides of the slot so the slitting saw can cut very freely and take a heavier chip load. Higher production can then be the result.
Stanley Dornfeld
San Diego
Stan Dornfeld
