Small Plate Straightening Machine?
Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Default Small Plate Straightening Machine?
    I have a small plate that gets punched out of .134" thick 1050 strip. The part is about the size of your hand. It comes out of the press slightly dished-shaped...mabye .020" bow on a surface plate/indicator. It would be super duper if there was a machine we could feed these parts into and have them come out within maybe .005" flatness. I'm picturing a big plate straightening machine only smaller, where there's alternating rollers above and below the part that become progressively closer together to almost cold-rolling the material thinner and you would feed the parts through like you would a thickness planer in a wood shop? Does anyone know if there is anything like that out there? Thank you!
    Jun 2012
    Michigan
    13,444
    4570
    4840
    A simple bench arbor press likely could be set up to push the part to better than .005
    Airpower press would also do the job.
    Palmgren Air Operated Bench Press - 9661604 - Penn Tool Co., Inc
    likely run 300 to 800 an hour with a simple set up.
  3. Likes Trueturning liked this post
    Oct 2005
    21,576
    Quote Originally Posted by Nerdlinger View Post
    Yup, I bought one....for a friend.
    It is an "Uncoiler" to feed a punch press, and it can hold a large roll of material 6" wide max.
    It feeds into a series of upper and lower rollers, total length of this part of the machine is maybe 12"-16" long. These are set to flatten the material
    just before it goes in the punch press.
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Quote Originally Posted by michiganbuck View Post
    Would you just put the part on some blocks and smash em all to the same point (like setting a stop on a manual drill press)? I’m not sure the parts are consistently off by the same amount for that to work. Like some might be off by .020” and some might be off by .010”. But maybe I can just split the difference?
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Yeah, that’s about what I was thinking! I actually tried this with our coil feeder for our punch presses but it didn’t work....but maybe there’s one better-suited for my exact application. Or maybe I need to try harder with the one we already have. Thanks!
    Oct 2009
    Louisville, KY, USA
    1,127
    221
    285
    If the distorting is from the punching operation it might be corrected by changing any crown or shear in the punch.
  8. Likes BT Fabrication, boslab, Nerdlinger liked this post
  9. #7
    Oct 2017
    1,303
    412
    442
    Can you curl the material the other way before punching?
  10. #8
    Mar 2005
    Kansas
    8,565
    590
    4308
    If your part is getting distorted in the punching process, fix the punching process.
  11. #9
    Oct 2005
    21,576
    Quote Originally Posted by gbent View Post
    Yup, increase the stripper pressure would be the easiest place to start.
  12. Likes Nerdlinger liked this post
  13. #10
    Jun 2012
    Michigan
    13,444
    4570
    4840
    Good to check that they are close to the same. The material would need to be constant for the amount of dish to be consistent. A manual drill press would not be suitable. A homemade swing arm could likely do the job. The part would need a fixture to push into, it would be tweaked until the desired change was made.
    *A photo or sketch of the part would help.
    A homemade swing arm likely would work.
    Coining a part can sometimes make better but that is a progressive die and I don't you seem to not wish to go to that expense.
  14. Likes Nerdlinger liked this post
  15. #11
    Jan 2007
    wales.uk
    1,713
    349
    386
    Laser it out, I’m told less distortion if pack cut, though all the plate I’ve cut is 10-16mm, with no real tolerance on flatness better punches, tighter punch to die clearance and a brutal stripper, I mean silly big springs seemed to work with Ali the punch is displacing metal I think, perhaps jig drilling might be a better way to go?
    Mark
  16. #12
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Quote Originally Posted by Strostkovy View Post
    It might be possible...we buy it in 12' strips. Thanks!
  17. #13
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    Touche'! The punch used to be a "V" shaped taper punch because the 100 ton press we have was the biggest one we had at the time the die was made(or so the story goes) Now we have a 250 ton press so I talked to the two tool and die makers we have (pretty good, experienced chaps) and we decided to take the taper out of the punch and make it "flat." It got a little better but not much. Maybe there is more we can do there, though, so I'll give it another go there. Thanks for the "wake up" call!
  18. #14
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    yeah, I imagine the "buckling" of the part from the shear on the periphery must be overcoming the pressure pad hold down force. So maybe we just need some stronger springs in there. Thanks!
  19. #15
    Jun 2012
    Michigan
    13,444
    4570
    4840
    QT: [slightly dished-shaped] concave or convex to the punch?
  20. #16
    Aug 2013
    Chicago, IL
    1,268
    913
    512
    The part is convex relative to the punch. In addition to the outside periphery of the part being cut there are holes on the inside of the part being cut at the same time, so it is a compound die that results in the part having a common burr side all done in one shot. There is a large hole in the center of the part and it sure looks like the part is actually more "V" shaped instead of "bowed." (With the large kidney bean feature being the bottom of the "V".) I will look into the actual "shape" of the part more closely. To be continued...
  21. #17
    Oct 2017
    1,303
    412
    442
    I'm no expert, but is it possibly the part could be distorted in the ejecting process? I.E., is the retracting punch pulling the part into a bow shape?
  22. Likes michiganbuck liked this post
  23. #18
    Jun 2012
    Michigan
    13,444
    4570
    4840
    I'm no expert, but is it possible the part could be distorted in the ejecting process? I.E., is the retracting punch pulling the part into a bow shape?
    Could need a more solid stripper.
    Did the part ever come out flatter, like when the punches were new/sharp?
    Does the set up/die have a spring or plate stripper?
  24. #19
    Mar 2005
    Kansas
    8,565
    590
    4308
    I see a very uneven radius around the blank. Post a picture of the exit side, it tells a more complete story.
  25. #20
    Jan 2016
    New York
    295
    6
    81
    I am going make an assumption that your stamping the part in a plain blanking die. A compound die may solve your problem. We really need more information about your stamping process and requirements.
    Roger
