Hi,
I am trying to make a single piston pump. I will use a honed steel pipe for cylinder. And also use a polyamid head and a steel shaft for the piston.
I have reduced the diameter of polyamid workpiece 52mm to 50mm with a hss 4 blade tool on a rotary table. By the way polyamid surface was a little bit rough after milling beacuse of heat and other factors.
Now the question, Which tool can i use to finish the surface of the polyamid ? (i don't have a lathe)
