snap ring grove question.
Results 1 to 18 of 18
    Mar 2013
    galt California
    146
    37
    68
    Default snap ring grove question.
    I have been a maintenance machinist for almost 30 years , I make a lot of simple parts and shafts ect . I also repair a lot of parts by welding up and turning ect .
    I had a block yesterday about 6 inch x 4 inch with 2 bored bearings in it held in with snap rings , and was thinking how I would re cut them if needed .
    it would be a pain to have to dial them in on a 4 jaw or possibly set them up on a rotary table with a thin type woodruff type cutter .
    So my question is their a special tool or way to cut these on a mill with a boring head?
    also I only have manual Bridgeport mill and a lathe.
    Jan 2014
    Temecula, Ca
    2,737
    1242
    3556
    never used one myself, but I believe that's what these are for,
    Grooving Head - Products
    Nov 2014
    Florida
    3,426
    1474
    1617
    Quote Originally Posted by Larry Dickman View Post
    That's pretty cool, but probably also serious coin. I doubt it is a reasonable solution for 'maintenance' type things. I would just say the OP is going to have to do it how he originally thought, 4 jaw or rotary table.
    Mar 2009
    Brunswick Oh USA
    4,492
    4964
    2676
    You could use a boring and facing head.
    https://www.ebay.com/b/boring-facing-head/bn_7024876531
  5. Likes digger doug liked this post
    May 2003
    4,495
    252
    Odd shaped parts like castings for power transfer cases can be done in a mill with a Wohlhaupter type head often much easier then using a lathe. Cutting snapring,oring grooves, and facing, one can make almost invisible repairs to damaged welded up castings.
    Apr 2009
    Beaver County Alb. Canada
    1,842
    532
    906
    Fairly easy to dial in on a lathe, use a COAX dial.
    Good practice.
  8. Likes CalG, CHPZ_HAPPEN liked this post
  9. #7
    Mar 2006
    jacksonville,fl.
    1,069
    909
    352
    I have several Narex B & Facing heads I could cut them with.However a lot of hard to hold parts I can always find a drop to make a light press mandrel and do them in one of the lathes.Really quick and not necessary to have a lot of speed.
    I also have a lot of internal & external grooving tools for the various widths.The cheap $7-20 Chinese internal/external bars(that use dog bone inserts) work really well.
  10. #8
    Mar 2005
    Kansas
    7,410
    424
    3393
    You can cut snap ring grooves with a standard boring head. Set up the proper cutter and feed the boring head out until the cutter touches the bore. Feed the boring head out a thou or two, and rotate the boring head by hand. Rinse and repeat until the proper depth is reached. Use spindle power for the final depth. Most snap ring grooves are so shallow this method may be faster than changing tools to a facing head.
  11. #9
    Feb 2018
    74
    Quote Originally Posted by gbent View Post
    I've done it the same way many times.
    No need for a fancy Boring/facing Head
  12. #10
    Jan 2005
    CANADA
    Saskatchewan
    10,189
    1382
    3659
    And whatever you do, don't touch off the bore and then move equal amounts in all 4 quadrant directions, and then do the same at the 45 degree offset positions. Never do that for rough counterbores for screw heads, either.
  13. Likes Hbjj liked this post
  14. #11
    Langley, B.C.
    1,637
    325
    960
    Another trick I learned when doing it this way is to use a boring bar with some extra length, This gives it a
    little "spring" so you can make your cuts in steps of .005" or so. If you've got a bunch to do it gets a bit tedious
    but for "onesie-twosies" it works fine. I've never tried turning the head by hand, always just powered up the
    spindle for each pass,
    Quote Originally Posted by HuFlungDung View Post
    I'm trying to wrap my head around what you're saying and I'm coming up blank. I know you're a competent
    machinist so it must be my comprehension skills this morning. Care to clarify?
  15. #12
    Mar 2013
    galt California
    146
    37
    68
    Thanks to everyone for their input , my plan was to check the thread a few times yesterday but every machine in the factory decided to turn to shit .
    the idea of slowly feeding the boring head out a few thou at a time will work, I rarely need to cut a grove on a odd part but was just thinking man theirs got to bean easier way. thanks guys.
  16. #13
    May 2011
    New Jersey
    1,918
    173
    1042
    Quote Originally Posted by jumpinjimmy447 View Post
    There is a MUCH easier way...let someone else do it
  17. #14
    Jan 2005
    CANADA
    Saskatchewan
    10,189
    1382
    3659
    Quote Originally Posted by LKeithR View Post
    It is basically 8 points of interpolation. With a cutter radius close to the bore size, the lobes at the bottom of the groove are minimal. You could do 16 points if you wanted to, but you'd discover that there's nothing much to cut.
    Using a 2 axis DRO, it's easy to calculate the 45 degree positions by .7071 * offset along the quadrant lines.
  18. Likes Garwood liked this post
  19. #15
    Aug 2008
    near Cleveland
    813
    55
    104
    I'm for using the lathe: use strap clamps on a faceplate and a conventional groove tool. It's quicker than a rotary table on the mill, 'specially if you have a small faceplate you can grab in the three jaw chuck (Even if you have to change out the chuck for the faceplate, it's still faster).
  20. #16
    Dec 2008
    Vt USA
    6,734
    736
    2316
    I can't imagine not using the lathe.
    Unless the lathe you have is too small.
  21. #17
    Jan 2014
    Temecula, Ca
    2,737
    1242
    3556
    Quote Originally Posted by CalG View Post
    I have a customer who send me some arms to put the ring grooves in. They're a conventional shop with no CNC. Why don't they just chuck it up on a lathe? Maybe because it's 4 feet long.
  22. Likes HuFlungDung liked this post
  23. #18
    Aug 2001
    Batavia, IL USA
    1,991
    57
    64
    Waldes Truarc used to make an internal grooving tool that used custom HSS cutters. I have what looks like a salesman's sample with part of the body cut away to show the internals. Interesting gadget.
