Softening hardened cast iron
Results 1 to 17 of 17
    Jul 2011
    New Orleans
    66
    5
    Default Softening hardened cast iron
    I have a casting off a drill press that had a setscrew which had been overtightened and cracked off a piece of the casting. I built it up with brazing rod (Harris Stay-Silv 15) and was going to drill and tap for the new setscrew but it appears I didn't allow it enough cooling time, it's now so hard I can't drill it with HSS. I'm sure I could get through it with a harder drill but I'm worried I will break a tap off in there and/or run into cracking issues in the future from embrittlement. Can I fix my mistake by heating it up and allowing it a proper long cool? I could either go old-school with a torch and a bucket of sand, or put it in my heat treat oven. Thoughts? If I go the oven route can anyone advise on temperatures and times? If torch what is the target, a dull red? In that area or the entire casting? Casting is not large, maybe 12"x8" with average thickness about 1/2".
    Sep 2006
    SW Wisconsin
    734
    206
    268
    If it is the cast that got hard then put in your oven at 1250F and let cool slowly. If it is an inclusion or a slag pocket then you may have to grind it out and start over.
    Ed.
    Oct 2017
    1,302
    411
    441
    I have in the past drilled an oversized hole, brazed it closed, then drilled and tapped that instead of the base metal. Works okay if you can't change the hardness of the material.
    Jul 2011
    New Orleans
    66
    5
    Quote Originally Posted by atex57 View Post
    Ed.
    Thanks. The heat treat stuff I've been reading seems to say cool at 100 degrees per hour but my oven doesn't have an automatic cycle so I was thinking bring it to temp, hold for an hour, then cool about 150/hour to 600 or 700 and then bury it in sand so I don't have to keep tending it.
    Aug 2015
    Illinois
    1,681
    1281
    730
    Quote Originally Posted by calderp View Post
    Just let it cool in the oven.
  6. Likes Matt_Maguire liked this post
    Sep 2006
    SW Wisconsin
    734
    206
    268
    1250F is below the lower critical temperature so it will not harden and does not have to be ramped down. This temp is really more of a high "tempering" temp to soften it.Cool it in the oven as Illinoyance said.
    Ed.
    Jun 2008
    Bellingham, WA
    4,440
    1101
    2515
    I think you are going to need a higher tmep than 1250. You can try 1250, but do not be surprised or disappoointed if it has little effect. 1650 to 1750 will anneal it and what was white iron will be soft and uniform grey iron. Problem is the silver braze will melt well before that. You could weld grey iron into the defect and then anneal the part. Lots of work. Maybe you'd be better off to "cast" a new part with your welder and some steel stock. Most likely you'll be done sooner and have a much more satisfactory part if you just fab a steel replacement. If your welds are not pretty, a little bondo can make a strong but not stack of dimes weld look very nice. Paint hides a lot. Maybe not the answer you were hoping for, but a practical approach I think.
    Denis
  9. #8
    Jun 2013
    New York
    901
    609
    479
    I would stick it in the oven at 1100F and let it bake for an hour. Then let it cool off naturally in the oven, overnight. Your solder has a solidus of 1190 and a liquidus of 1480.
  10. #9
    Sep 2006
    Nevada
    407
    29
    105
    I used to have to anneal some small cast parts that I used to sell. The thin sections would cool down to fast and be extremely hard. To anneal I would put into a furnace and take the temperature up to 1750 degrees, hold for 1/2 hour and then do a controlled cool down of 50 degrees every 1/2 hour until the temperature reached 900 degrees and then I just let it cool as fast as it could.
  11. Likes dgfoster liked this post
  12. #10
    Virginia
    19,707
    7561
    11847
    WHERE on what size of DP, and for what function? So we have some idea how hard it has to work at its job.
    "On speculation" knowning nuthin' else, I'd be more concerned as to cracking again than over threads for a setscrew.
  13. #11
    Oct 2009
    Louisville, KY, USA
    1,127
    221
    285
    You'll want to make sure your softening temperature is well below the melting point of that stay-silv.
    Harris' website shows a solidus point of 1190°f.
  14. #12
    Feb 2004
    peekskill, NY
    26,849
    6172
    Some of the hardest stuff I've seen was the small cast-iron pulley housings for the double-hung widows in my 1850s vintage house.
    At one point I tried to shorten one up a bit to fit in a different window, the stuff is harder than billy goat dicks.
  15. #13
    Mar 2009
    Eureka, CA
    4,364
    1016
    1746
    Quote Originally Posted by jim rozen View Post
    Would you care to share with us how exactly you know this fact?
    Stuart
  16. Likes pavt, 72bwhite liked this post
  17. #14
    Mar 2005
    Indiana
    5,989
    2050
    2029
    Quote Originally Posted by atomarc View Post
    Stuart
    Totally opened yourself up to a "Yer momma told me" on that one.
  18. #15
    Jan 2016
    New York
    295
    6
    81
    Default Slow Cooling
    Get a sack of lime and bury your part in the lime to cool. It will be even slower than sand.
    Roger
  19. #16
    Jun 2008
    Bellingham, WA
    4,440
    1101
    2515
    You could bury it in something even more insulating than sand, if desired. But, it may be useful to remember that the part was originally cast in sand with 4% moisture added. I remove my cast parts from their green sand molds 4 hours or so after casting and measure the sand temp at that time. It is usually down to around 200 degrees. Given that I cast at 2580F it has cooled far faster than 100 per hour! And the grey iron parts are soft and machine (and scrape) beautifully. Heating them to an inadequate temp (1200 is too low) with very slow colling will do nothing to soften them. Heating to 1750 with cooling at 300 per hour will anneal them to buttery softness.
    Denis
  20. #17
    Jun 2012
    Eastern PA
    1,160
    359
    564
    Hey, it looks like someone has hacked Thermite's account.
    Obviously, this short post (above) couldn't have been by the real Thermite.....
