David_M
Hot Rolled
- Sep 30, 2014
- Midway, GA, USA
This is a link to a program to find the change-gears when cutting helical gears while not using a differential. It is for 64 bit Windows 7 and newer.
The program's name is 'Helical Gears.exe'. You will also need to download the DLL file named 'libiomp5md.dll'. Place it in the same folder as the executable such as the desktop folder (there is the possibility the DLL will need to go in the 'windows\system32' folder depending on how the search path is setup).
https://1drv.ms/f/s!AjRYB9hC1AwCnznkaB-nTG2qGyjR
Double check results before using.
