Some assistance please with 1045
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    May 2011
    New Jersey
    568
    11
    193
    Default Some assistance please with 1045
    I have a 1510 ford tractor and the valve rocker arm is busted. The part does not exist because it was a low production machine and OEM parts are no more. Can't locate the part at several very large ford tractor junk yards across the country.
    So, I want to make the rail myself. I searched google and a nice topic from practical machinist came up saying use 1045 since its already designed for the job.
    I ordered a piece and started playing with it last night. Now I normally machine 303,304,316 stainless in my manual machine. 17" south bend tornado. I see this stuff almost burns as it cuts.
    So I'm not trying to blow a ton of money on Tooling to figure out 1 small project that I may never do again. Problem is I want the tractor back so I can clean up my yard for a party in a month and machine shops aren't going to get it done for me. Which I understand, hence why I'm going to do it.
    I ordered the tube from Mcmaster with a close enough id and I need to turn the OD from 0.75 to 0.668.
    Any help on tooling and speed/feeds would be very helpful.
    Sent from my 2PS64 using Tapatalk
    Dec 2009
    Louisiana
    425
    141
    240
    these low carbon steels need a decent depth of cut to get a shear going other wise they just tear and leave an awful surface finish. If light cuts are all you can do I'd recommend grinding your HSS bit very sharp at a positive angle and cut in oil.
  3. Likes Gobo liked this post
    Dec 2015
    Illinois
    385
    125
    215
    I would use sharp tooling with lots of relief, such as an insert intended for aluminum. I would also try to keep the sfm down to keep from tearing up the cutting edge.
    May 2017
    FINLAND
    1,632
    463
    760
    1045 "burns"? Induction hardened by any change?
    Can you be more specific? It should be really easy to machine and not overly picky of anything.
  6. Likes Mtndew liked this post
  7. #5
    Dec 2008
    New York
    10,033
    2609
    4140 steel is a popular steel
  8. #6
    May 2017
    FINLAND
    1,632
    463
    760
    Quote Originally Posted by DMF_TomB View Post
    You won't solve anything by switching from 1045 to 4140 machinability vise. Better just sort out the original problem.
  9. #7
    Jan 2005
    Houston
    5,513
    475
    2345
    1) A photo sure would be nice.
    2) Are you making a rocker arm or a rocker arm shaft? It sounds like a shaft you are making but clearly you refer to it as a rocker arm. The rocker arm is the thing that...rocks...and pushes on the valve tip. The shaft is the cylindrical tube that the rocker might or might not pivot on.
    3) 1045 is pretty easy to machine as far as steels go. If it's 'burning' that gets a WTF.
  10. #8
    May 2017
    FINLAND
    1,632
    463
    760
    Any change that your "tube" is this?
    Hollow Linear Motion Shaft
    Last edited by MattiJ; 05-09-2018 at 01:08 PM. Reason: Goddammit, linking to MCM can be "#%"#¤
  11. #9
    Mar 2017
    LATVIA
    300
    76
    163
    MattiJ is probably right
    by "burns" OP probably means glowing chips, which in turn will mean that the 1045 in question is hardened, and razor sharp HSS will be of no use there, carbide will do the job, but might need a follower rest if that shaft has some legth to it
  12. #10
    Dec 2008
    New York
    10,033
    2609
    Quote Originally Posted by MattiJ View Post
    i machined plenty of prehardened 4140, not super hard and usually fairly high strength. i have known engineers who often asked for it
    machines ok with carbide. might have some tapping problems other wise it machines ok
  13. Likes Gobo liked this post
  14. #11
    May 2011
    New Jersey
    568
    11
    193
    Wow, overworked and unappreciated by my customers and 2 kids, take your pick at what connects to what.
    Yes it's the 52100 from Mcmaster. I'm working in a 1045 part for another machine of mine and switched info.
    Thanks for correcting me.
  15. #12
    May 2017
    FINLAND
    1,632
    463
    760
    Quote Originally Posted by Bondo View Post
    No wonder you have problems. It's a rock hard high carbon bearing steel.
    If you want to try carbide try reeally slow speed, like 100 sfm. Seco TH1000 grade has been recommended more than once over here.
    Or go to Ceramic or CBN and let the fiery orange hot chip fly! time to read up on "hard turning".
  16. #13
    Jan 2005
    Houston
    5,513
    475
    2345
    If you are making a shaft, I think the guys who do it start with unhardened material then harden it after...maybe a final grind is all they do after hardening.
  17. Likes 72bwhite liked this post
  18. #14
    Sep 2012
    California, Ventura county
    1,407
    256
    602
    that's a tough one trying to turn woodpecker lips hard material
    what you need is a grinder
  19. #15
    Feb 2013
    Madison, WI
    953
    1093
    612
    MattJ is in the ballpark on 100sfm. Low depth of cut like .02" starting at .003"-.004"/rev.
    This is where I would start anyways. A decent steel grade WNMG TiAlN coated insert should be able to get the job done for ya.
  20. #16
    Mar 2005
    Northwest Indiana
    3,920
    631
    720
    Might not be the way to go if that linked tubing is what you've got. The link says it's case hardened. By the time you cut it down to the diameter you need you will probably lose a lot of that hardness. Depends on the depth of the case. Might be better off roughing it down close and getting it heat treated again - leaving just a bit for finish grinding or turning - I'd advise grinding seeing the length and wall thickness. Unless the rockers pivot on a bearing, in which case you don't need that hard of a shaft. If they pivot directly on the shaft then you'll probably want it pretty hard.
  21. #17
    Jun 2008
    TN
    1,545
    323
    250
    A picture of the old part would be very helpful!
  22. #18
    May 2011
    New Jersey
    568
    11
    193
    Quote Originally Posted by henrya View Post
    Wow, now I feel stupid... Yeah that would help. When I get back to the shop I will take a picture
  23. #19
    Dec 2008
    New York
    10,033
    2609
    again 4140 preharden is often used to make parts and no other heat treatment needed. its moderately hard so carbide works better. it can be moderately difficult to drill and tap with hss but it normally can be done
  24. Likes DJ2 liked this post
  25. #20
    Apr 2004
    Shandaken, NY, USA
    4,263
    1131
    6715
    This may be "locking the barn door after the horse has run out", but: have you checked the hardness of the original/broken part ? Without going into a formalized hardness test, checking the undamaged portions with a file and center punch should give an idea if the rocker shaft is hardened. If you have a fractured surface, try your center punch across it, working from the outer circumference in towards the center bore (rocker shafts usually being made hollow). This will tell you if the shaft was through-hardened or surface (aka "case") hardened.
    A spark test done on a bench grinder can also give a rough determination of carbon content and alloying elements. If you take some specimen pieces of steels of known compositions and spark them first, then compare the rocker shaft's sparks, you can often get a pretty good idea of what basic elements and approximate carbon content in the shaft is.
    A rocker shaft usually has some holes drilled into it for locating it or for getting oil up to the rockers, so whatever you make the replacement shaft from has to be something you can drill and possibly ream or tap, depending on the design of the shaft. A soft steel which can later be hardened or surface hardened is what I'd use. Something like an 8620 which can be machined easily in its soft condition, and can be surface hardened with minimal distortion would be my choice. I'd send the shaft out to a commerical heat treaters after you machined it and have it surface hardened perhaps 0.020-0.030" deep. It is your call as to whether you want to leave a grinding allowance and finish grind the shaft to final outer diameter/straightness.
    For a rocker shaft in a tractor engine, I'd be OK with surface hardening at final diameter. I'd check the actual clearance of the rocker arms on the undamaged sections of the shaft, and if there is a couple of thousandths of clearance, I'd go with the shaft at final diameter before heat treating. I know from experience that some steels tend to "swell" or "grow" a bit when hardened or surface hardened. Usually, final grinding is called for, and this brings the hardened part to final dimensions, so this is not an issue. In your case, you may want to make the shaft maybe minus a half thousandth to allow for "swell" which sometimes occurs with surface hardening. I'd then polish the shaft with emery cloth and crocus cloth in the lathe and run with it.
    No disrespect to you or the tractor, but you are not making parts for a high speed high performance engine like a Ferrari or Maserati. Try to match the hardness and dimensions and you will be good to go without splitting the ten thousandths of an inch.
  26. Likes DJ2 liked this post
