I inherited an Atlas Clausing 10100 and several milling accessories. I am still learning about this lathe and about lathe operations. I also inherited a “Holding Collet Set, No. M6-945”. The set is composed of a draw bar, sleeve and arbor. I don’t have the sleeve but I will try to fabricate it. Attached is a link to an old accessory ad for the 10100. Does anyone have this accessory and would you be willing to send a photo with dimensions for the sleeve? I assume it simply serves as a bracing sleeve to allow tension to be applied to the threaded 2MT arbor without damaging the spindle.
Atlas 6-inch Accessories
