Source, die shoes-sets?
Results 1 to 12 of 12
    Jun 2003
    Mebane North Carolina USA
    6,893
    53
    2111
    Default Source, die shoes-sets?
    Who sells light duty (cheap) die sets for light stamping and assembly. Need a couple new or lightly used for a school project. Maybe 3x5 opening. Can work around what I can find.
    Jul 2004
    Southeast Michigan
    6,924
    275
    1750
    they have gotten somewhat hard to find. i'll check today to see if i still have a pile of them, if i do you can have one for shipping. you'll probably have to derust it to a degree.
    i don't even know what danly sells them for, or if danly is still alive.
    Sep 2018
    Michigan
    117
    24
    61
    New sets have a fairly long leadtime unless you are talking an off the shelf item.
    Anchor Canly stocks small die sets as a catalogue items.
    For fab die sets, We use either Anchor Danly, Steelcraft, or Integrity Fab and Machine.
    My preference is Integrity Fab, they send their grinding to a dedicated grind house, which typically results in a better end product. (anchor and steelcraft grind in house, We have often had issues with flatness from those two)
    Oct 2005
    20,652
    I designed a couple of testing rigs last year, using ones with maybe 5/8" pins, 4" x 6"
    between pins.
    Mcmaster carr $600.
  5. Likes Thunderjet liked this post
    Nov 2014
    Florida
    6,018
    2376
    2988
    Danly Die Set Die Shoe Punch Press | eBay
    Fleabay maybe, dpending on if you can work around existing holes, and afford the shipping.
    Apr 2017
    Wisconsin
    13
    I usually buy from Janesville Tool
    They stock quite a bit so lead time is pretty quick.
  8. Likes digger doug liked this post
  9. #7
    Mar 2014
    Michigan
    878
    203
    351
    I was thinking 3’x5’.
    For something that small why wouldn’t you just make them?
    Mill or grind a couple pieces flat, clamp together, a few small tack welds, drill & bore for pins, open holes for bushings and you have your die set. I bet you wouldn’t have 2hrs into both sets.
  10. Likes digger doug liked this post
  11. #8
    Jul 2004
    Southeast Michigan
    6,924
    275
    1750
    I have two of these. 4x4.....not sure if the pins are long enough.
  12. #9
    Jul 2004
    Southeast Michigan
    6,924
    275
    1750
    Not too bad as far as stuff to work around.
  13. #10
    Jul 2004
    Southeast Michigan
    6,924
    275
    1750
    Quote Originally Posted by Mebfab View Post
    Let me know if those will work and I’ll get them in the mail to you. I’m a sucker for educational projects, so it’s just the cost of shipping (I think medium flat rate) if they’ll work for you.
  14. #11
    Jun 2003
    6,893
    53
    2111
    That is perfect. Going to make some type of simple die to go in to demonstrate. . Will it fit in flat rate box?
    Dan
  15. #12
    Jul 2004
    Southeast Michigan
    6,924
    275
    1750
    they should both go in a flat rate, send me a pm with your mailing address. i'll put some urethane in it as well.
