Source for M7 screws in stainless steel?
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2017
    New York
    134
    10
    55
    Default Source for M7 screws in stainless steel?
    anyone know of a source for M7-1.00 screws
    Like this but any form of stainless steel:
    McMaster-Carr
    It's for a shift shaft pinch bolt and I want to turn the end that sticks out to M6-1.00 to install a quickshifter sensor that has a 6mm hole size
    Jul 2006
    Hillsboro, New Hampshire
    7,732
    1807
    5431
    Buy the right length of these: 2Pcs M7 Allen Screw Stainless Steel Hex Socket Cap Knurled Head Bolts 10mm-50mm | eBay
    Either use as-is, or get a longer one, cut for thread lenght plus a bit for a machined hex plate, weld plate to thread. I'd just go with the socket cap...
    Feb 2008
    Illinois
    1,097
    65
    385
    The correct ISO description for a STANDARD M7 screw 10mm long is: M7x10 (or x16, x20, x30 etc)
    The correct ISO description for a FINE M7 screw 10mm long is: M7x0.75x10
    M7 is not a common size but used as a special size by some manufacturers. M6 and M8 are.
    US & Metric Thread Standard Chart | Carr Lane
    Thanks to ANSI for screwing things up for the US.
