Greetings from Canada. My work has a new 1" capacity Swiss lathe on the way, which will be our first swiss machine. Looking for suggestions on where to get good quality h9-or-better tolerance aluminum bar stock (we need both 6061 and 7075). No problem buying from the US. We need a small amount of 416 SS too. Have googled and emailed and called a number of vendors now and found it surprisingly difficult to get straightforward answers.
Another query for the swiss turning gurus - are you using ground stock or cold rolled? If you're getting it ground, are you having it ground to a standard (ie round number) nominal size (eg 0.500") which I think would require an over-nominal size extrusion to grind down, or are you getting it ground down to a slightly below-standard-nominal-size (eg 0.490")?
Any advice appreciated.
