Specifying sharp threads on drawing
Results 1 to 13 of 13
    Mar 2019
    New York
    15
    11
    Default Specifying sharp threads on drawing
    So I am considering the possibility of having an evenly spaced round blade made, so if it dulls we can rotate it a few degrees. I was thinking our machine shop might be able to just turn a threaded rod on their lathe at the required TPI, and we could mount the threaded rod on an angle to cut what we need. Is there a good way to specify on the drawing that we need the threads to be as sharp as possible? Thanks!
    Dec 2015
    Illinois
    506
    183
    309
    I think you would be best off speaking directly to your machine shop and explaining what you want. From the outside with little information I'm curious what you are cutting and if you would need to make your "thread" out of something hard enough that grinding would make more since.
  3. Likes AHUNT, Winterfalke liked this post
    Sep 2007
    Washington
    5,456
    236
    1711
    This made sense to me:
    Regards.
    Mike
  5. Likes Oldwrench, AHUNT liked this post
  6. #4
    Jul 2006
    Arizona
    4,714
    18778
    4561
    Quote Originally Posted by AHUNT View Post
    The threaded rod will act like an auger if it will be spinning and not do what you want it to do.
    Instead specify a series of grooves with sharp tips.
  7. #5
    Sep 2010
    Oklahoma City, OK
    5,130
    940
    2163
    Quote Originally Posted by Philabuster View Post
    If he angles it right wouldn't it cut straight, like a hob?
  8. #6
    Jan 2007
    Flushing/Flint, Michigan
    9,142
    501
    7570
    Are you trying to make a forming tool or a cutting tool?
  9. #7
    Mar 2019
    New York
    15
    11
    We were going to lock the rotation of it. We would want to be able to unlock it rotate it a few degrees and relock it.
  10. #8
    Mar 2019
    New York
    15
    11
    We are making a cutting tool.
  11. #9
    Jan 2007
    9,142
    501
    7570
    With that I'm confused as to where the chip formation and shear occurs.
    I get it as metal spinning or forming tool. I don't get the cutting action.
    I'm missing something as to how this works. Is it sort of used like a broach?
    Bob
  12. #10
    Dec 2015
    Illinois
    506
    183
    309
    I'm imagining it slicing like a knife, like when you try to turn a piece of brass all-thread by hand and get a line of cuts instead .
  13. Likes Winterfalke liked this post
  14. #11
    Jan 2007
    Norfolk, UK
    20,229
    15631
    16022
    Quote Originally Posted by Cole2534 View Post
    Due to the helix angle ;- Not unless whatever he's cutting (like a gear) rotates in sync, with the cutter
  15. #12
    Jan 2007
    9,142
    501
    7570
    He wants to rotate it a few degrees when dull for a new edge.
  16. #13
    Nov 2010
    UNITED KINGDOM
    990
    197
    242
    Are you cutting, paper, card, foil, plastic sheet, leather or what?
    How many TPI?
    How long is the threaded bar?
    What diameter?
    Does it have to be Sliver Steel/ Drill Rod so it can be hardened?
    Is depth of cut normal thread depth?
    How is the material being cut moved across the threads?
    Thickness of material being cut?
    Trying to visualise just what is happening.
  17. Likes Limy Sami liked this post
