Spindle Max RPM Duty Cycle
Results 1 to 2 of 2
    May 2018
    New York
    132
    106
    79
    Default Spindle Max RPM Duty Cycle
    I just came across this: YouTube, I remember being told the machine will run 15K RPM all day and so did other members here think, seems like it will kill the spindle prematurely, the case is probably the same with other MTBs?
    Jul 2006
    Hillsboro, New Hampshire
    9,209
    2185
    6380
    All mechanical bearing systems have a rated life, which they can exceed or fail before depending on use and luck. Sort of like humans - we can make it to 80+ or kick-off at 40, even if both parties had identical lifestyles.
    If you're a prototype shop without pressure for throughput, run the spindle slower, it will likely extend bearing life. If part output is critical to the company, run full-bore and budget for replacement or repaired spindles along the way.
  3. Likes rpseguin, Jmaks liked this post
