That's right Larry. You have a good eye for detail. Most of the people I run into are too poor to pay attention and don't plan that far ahead.
After reading John's post, I am back to scratchin' my head a little. The studs on a B tool have threads and go though a clearance hole in the spindle flange, which there aren't any of with this chuck. The through holes on the chuck indicate it's for an A spindle that has threaded holes in the spindle, but there is no area for the drive button/ screw. Jacobs website doesn't have any info on it. My best guess is that Jacobs intended for socket head cap screws to be used in lieu of the B studs. Either this thing is worth a mint because of it's obscurity or it's a glug and I should put it in the bass boat in case I go seining. (a glug is any object that emits a "glug" noise when thrown in a lake)
I don't THINK it is for the Hardinge taper, but Jacobs 9XX were available for those.
One other thing you might research. The proprietary Cazeneuve HBX spindle taper. ladner.fr has the dimensions, but IIRC, NOT the taper angle. 1.7 degrees?
My own Rubberflex chuck for it has the LARGE backing plate that picks-up on Cazeneuve's idea of "quick change". Three stout conical wedging tip screws that go into sockets on radials from the outer edge.
However.. the Cazeneuve spindle nose is dual-use. One can EITHER use those radial 3 screws ELSE through-bolts, parallel to the spindle axis, "A" family style.
One give-way is that the taper is longer but waaaay shallower as to angle than A / D1 series, yet much shorter than L series or Hardinge. There were about 30,000 or 40,000 of those lathes made, four factories, France, Japan, Spain, Brazil, so they are not as rare as some thinkle peep they are. My guess is they are still earning their keep rather than hitting the used market all that often.
AFAIK, the castings and spindle are still in-use on the current-production "Optica" semi-CNC replacement, too.
