rmcphearson
Hot Rolled
- Jan 12, 2008
- Rochester, NY
Looks like and old trailer electric brake set-up.
As mentioned above, tool retract.
My W&S automatic can leave those, but the
size of them indicates the tool was getting dull, and tool pressure was high.
I can eliminate most all of it by adding a second (finishing) tool, with a
small lead angle to keep deflection under cut down, retracting
doesn't have much to cut.
EDIT: Upon a second look, that turned diameter is not one of the (2) critical
sizes for the bearings, so it gets simply roughed, hence the rough finish,
and heavy tool pressure from running high feed with a large nose radius.
I don't know. I friend sent me this photo. He says all four look like this. I'm satisfied now it's a tool-withdrawal mark. I'm familiar with them on rough cuts but I never left one on a finished product. That's what threw me.Is the hand different on left and right spindles?
What he said X 2 ...............oh for the days when things like that didn't matter ....like stub axles on cars, the two different dia bearing seats, seal track and thread - all perfect, .............the taper in between - as rough as guts, as long as it cleared the hub - job done.
What is the purpose of this spiral groove?
Good story about an Archimedes screw on the Harley shaft, but for a trailer the spindle is stationary. The centrifugal force in the hub moves the grease to the outside of the hub, away from contact with the spiral groove on the clearance diameter.
I thought it looked familiar....
It's not a machine tool spindle, not a motorcycle engine
crank, not anything but a simple obsolete trailer spindle.
What Do Old Warner Trailer Brake Assemblies Look Like | etrailer.com
Nice one Doug, ........but they're still just tool retraction grooves
Notice
