Zahnrad Kopf
- Apr 5, 2010
- Tropic of Milwaukee
We've been tasked with the possibility of modifying some parts for a customer and after much contemplation am looking for more ideas on fixturing a part.
The part is basically a sheet metal stamping, and not flat, having offsets and perpendicular features that prevent simply laying them down and clamping.
Plus,... there might be 3,000 of them to do. It could even be as much as 6,000. We do not know yet. Discussions have me thinking it will be at least 3,000 though.
The modification itself is rather straight forward, and simple. Take .010"-ish off the highlighted face in the picture. So, obviously, I would like to be able to stack them and whack them. But their geometry is not very friendly for that. this leaves me thinking about how to best get the biggest bang for my machine-time buck, and considering a FAST method of fixturing as many as possible ( within reason ) to optimize our efforts.
Ideally, I would like to stack them side by side, so that the surface to be machined is parallel to the table, and an end mill can walk right over and by, hitting as many as possible in a pass. However, I am also open to laying 30 or 50 or so down, clamping, and using a small end mill to side cut them. Obviously, some ways are going to be more efficient, but I"m not ruling anything out so far.
Machine will likely be a machining center. ( 4ax capable if someone has some wild idea )
Any thoughts from out there in PM-land?
( for idea of scale, the thickness of the parts are ~ .100" and they are ~ 4.400" long )
