Strostkovy
Titanium
- Oct 29, 2017
I wind electromagnets somewhat often with a crappy desktop lathe and a parts counter. I've decided I want to setup a carriage to move the wire back and forth and keep the buildup of wire even. With that comes the potential for higher winding speeds now that my fingers won't be involved.
The trouble is I may be using fairly thin wire on fairly heavy spools, and to have a static brake to slow the roll enough with feed changes would be hard on the wire. I will of course be using minimal acceleration, but still.
Anyway, I want to mount a potentiometer on a tension sensing arm and send that amplified signal to a beefy solenoid or torque motor that can put tension on a brake band, and I'm unsure of materials to try.
The only similar thing I've done is put a piece of spring loaded felt on a ball bearing hamster wheel to fix overspeeding issues.
If I had to guess I'd start with a felt band on an aluminum wheel.
To give a sense of scale the breaking strength of the wire is 11 pounds and the spool weighs 80 pounds. Slow acceleration of the spindle is easier to achieve than slow deceleration.
