Squaring a stock piece to size
Results 1 to 16 of 16
    Dec 2018
    CANADA
    Ontario
    5
    Default Squaring a stock piece to size
    I know this is the very basics but I'm new to the machining world, if I needed the stock to be square but also to size. Let's say the block needs to be a 2" squared cube. What would be the best method to be able to zero my cutter and flycut or facemill my part to those dimensions?
    Langley, B.C.
    1,505
    303
    882
    May 2006
    Seattle
    1,739
    31
    312
    Whatever you do, rough the part out first. That means cut most of the waste away, leaving say .010" still to machine on each side. The right thing to do after that is to grind the piece to size using a surface grinder. If you only have your mill you will have to work very carefully to get it exactly right.
    And by the way it isn't real easy to mill a 2" cube within .001" everywhere and hold all the faces exactly square to each other.
    metalmagpie
    Nov 2013
    Utah
    3,907
    1061
    2146
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    Huh??
    It's easier than microwaved pie. Hold chunk, Mill top, and 4 sides with the same Tool, flip part, Mill top---done. Why use a Surface Grinder? Besides, you are applying tolerance to this "cube" not the OP (food).
    R
  5. Likes BSCustoms, HuFlungDung liked this post
    Jun 2012
    Michigan
    9,592
    2926
    3204
    QT: [flycut or facemill my part]
    Actually, to use an end mill perhaps ½ / ¾” or so might make better the part so taking out the need for near perfect tram.
    Two sides (4) can be made square with a decent mill and trued-in vise but the ends (side 5) need be square on the sides not jaw-touching with the likes of a hand square or indicting one of the not jaw touching two sides.
    To +- .001 not bad/not easy, but within .001 (so +- .0005) is not that easy on most mills IMHO.
    Having a open grinder handy I think to grind the last .003/.005 easier than trying to pull .001 on most mills.
    Same goes for making 123 blocks on a SG.. to hit sizes and be square all .0002 and less is not that easy..often thought to be a apprentice challenge it is a tough for a green guy.
    Nov 2013
    Utah
    3,907
    1061
    2146
    Sometimes I forget my frame of reference is mostly CNC. So .0005" on 5 sides is pretty standard fare. Sorry if I misguided anyone.
    R
    Oct 2013
    netherlands Asten
    773
    465
    312
    Huh??
    R
    and how would you hold the part?
  9. #8
    Jun 2012
    Michigan
    9,592
    2926
    3204
    Quote Originally Posted by janvanruth View Post
    Perhaps oven gloves might work...
    https://www.amazon.com/dp/B07K739YPR...i-a=B07K739YPR
  10. Likes litlerob1 liked this post
  11. #9
    Oct 2013
    netherlands Asten
    773
    465
    312
    Quote Originally Posted by michiganbuck View Post
    but they are silicone..
  12. #10
    Nov 2013
    Utah
    3,907
    1061
    2146
    If your part is 2"x2"x2", you get you a 2.25" power of 3 chunk, hold onto .2" of said chunk.
  13. #11
    Nov 2003
    Beaumont, TX, USA
    4,569
    155
    1339
    Milling vise on parallels.
    Toe clamps.
  14. #12
    Oct 2013
    netherlands Asten
    773
    465
    312
    Quote Originally Posted by EPAIII View Post
    Toe clamps.
    sorry but i still have trouble imagining it.
    if 5 surfaces needed to be milled in one setup the only surface to hold it would be the bottom surface.
    putting it in the vice would render the clamped surfaces unreachable.
    clamping it down with toe clamps would render the top surface unreachable.
  15. #13
    Nov 2017
    Washington
    5
    7
    Read Litlerob1's post #10 once more.
    Considering the vice method, if your stock size is 2.25" thick and your part is 2" in height, you will have additional material to hold onto. You do not need to reach the full depth of 2.25" on the clamped surfaces because you will be machining the bottom surface away in subsequent operations.
  16. #14
    Oct 2013
    netherlands Asten
    773
    465
    312
    Quote Originally Posted by InvoluteSpline View Post
    ok now i get it, thanks for the explanation
  17. #15
    Jun 2012
    Idaho
    3,096
    1680
    1998
    a vice of any worth should be able to grab even .100 with considerable grip and accuracy
  18. #16
    Jun 2012
    Michigan
    9,592
    2926
    3204
    What I see wrong with one or some of the YouTubes is that one can not mill cutter or fly cutter a part with not the tilt and nod square with the machine or square with the vise.
    If the nod for example is off one may cut the part .001 low at the front then flip the part to cut .001 off the same way. perhaps parallel but out of square with the solid vise jaw, so every flip can make more off.
    A small end mill will make perhaps 4 passes and look not as fancy, but will be more square with the solid vise jaw.
    Yes one can tram the head for tilt and nod with simple adding a shim in the axis that does not have an adjustment. If wishing to use a mill cutter or a fly cutter the head needs to be tram both ways.
    Yes one could fly cut(or mill cut) and with not taking the part out of the chick run an indicator two ways to see the tram error in the part.
