Stainless SHCS Torque Specs
Results 1 to 6 of 6
    Dec 2012
    ohio
    75
    Default Stainless SHCS Torque Specs
    I’m having trouble finding torque specs for M5 stainless SHCS. I can find info on other grades but can’t find anything on stainless. Anyone have any good resources?
    Take it easy on me with this possibly elementary question. Haha
    Thanks!
    Apr 2005
    Southwest
    586
    21
    35
    M5 usually denotes the size of the fastener, of course I am no expert on stainless steel specs. There are a grades A2-70 and A4-70 and A2-80 and A4-80. An M5 70's torque are 3.3 ft/lb while the 80's are 4.8 ft/lb. Not sure I have helped or hurt on this reply.
    Aug 2015
    Illinois
    1,540
    1152
    662
    That info is readily available on the internet. All you need to do is search for it. You should have done that before posting here.
    May 2005
    AZ
    2,448
    238
    831
    Google "holokrome" and see if that helps.
    May 2011
    New Jersey
    2,632
    248
    1416
    Can't go wrong with the German torque spec....guttntite
    Jul 2011
    Americus, Georgia
    452
    558
    135
    Torques values for cap screws are determined by the strength of the threaded hole the screw is engaging. Torques values for bolts are published in charts and available in most publicans furnished by the fastener manufacturer. If your application is critical, or if you want to apply maximum holding capacity, you need to stress test the joint to failure and determine the torque required.
    Bolts have nuts, screws do not.
  7. Likes tdmidget liked this post
