Standard 6061 T6511 ASTM B221 aluminum tube tolerances
Results 1 to 8 of 8
    Apr 2012
    Garnet Valley, PA
    91
    12
    6
    Default Standard 6061 T6511 ASTM B221 aluminum tube tolerances
    Good afternoon,
    I have been having a difficult time locating the dimensional tolerances of this 2" OD .065 wall aluminum tubing.
    Is it the ASTM B221 spec that defines it? I have no access to that spec.
    Diameter tolerance
    Roundness tolerance.
    This 2" tube we have is out of round.
    Measures 2.023 to 1.995 depending on where you measure it.
    Jul 2012
    Washington
    2,743
    1047
    1077
    I think this is what you want. From how I read it, not official, it looks like you are well within tolerance. Keep in mind the manufacturers have set the tolerance so it is VERY loose.
    Jan 2017
    Oregon
    2,457
    441
    1747
    Quote Originally Posted by DavidScott View Post
    That link is the Aluminum Association standard tolerances for bars and profiles.
    Here is aluminum tubing:
    https://www.marmonkeystone.com/ecomm...tion/A241T.pdf
  4. Likes Milland liked this post
    Sep 2007
    Washington
    5,126
    177
    1475
    I have had the same experience, with 3" x 1/8" tube. The product I was getting was welded, as seamless was way more $$ or unavailable. Out of round by up to .020" or so, average OD varies +/-.02", a real nightmare to try to fixture accurately.
    Regards.
    Mike
    Apr 2012
    Garnet Valley, PA
    91
    12
    6
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    I believe there is a cold drawn option that makes it more accurate.
    Langley, B.C.
    1,642
    328
    961
    What are you doing with the tubing? How round does it need to be? The most consistent stuff that we have found is
    drawn round tube with a wall thickness of .058". You can get sequentially sized tubes from 1/2" up that all telescope
    into each other...
    May 2005
    AZ
    2,329
    213
    789
    McMaster-Carr's online info is fairly extensive with respect to raw materials tolerances. That is usually my first quick stop for a material tolerance idea. That said, the tolerances ARE McMaster's own, at least with respect to some large U-channel aluminum extrusions we use. The McMaster catalog published tolerance is fully half of what the Alum.Assoc Standard allows. That was recently an issue for one of our suppliers when they got material from an alternate source. I was quite surprised as well, which led me to buy a copy of the Assoc. standards for reference.
  9. #8
    Apr 2012
    AR, USA
    955
    20
    174
    ANSI H35.2 is used for most aluminum tolerances. The mean diameter (the average of the biggest and smallest measurements) should be within +/- .015" of the specified diameter. The diameter at any point can be +/-.030" from the specified diameter.
