Standard Modern 1340 lathe question
Results 1 to 12 of 12
    Sep 2009
    Virginia
    153
    30
    22
    Default Standard Modern 1340 lathe question
    Good morning folks,I have a question about my standard modern lathe,I hope its okay to ask it here.My machine has a leadscrew and feed rod.Both turn when using feed on carriage.I was wondering if there is a way to disable the leadscrew when I,m only turning using the feed.This machine is probably 40 years old,it was in my high school metal trades class 33 years ago.Its kinda nice to have being one of the first lathes I used.It would be alot quieter if I could disable this when feeding.The serial number is 9288 if that helps.
    Thanks Rick
    guest Guest
    Don't know about your lathe in particular, but usually you just disengage the threading on the headstock.
    Sep 2009
    Virginia
    153
    30
    22
    i hope these pics load
    Attached Thumbnails Attached Thumbnails img_20190308_113904276.jpg   img_20190308_113843115.jpg
    Jan 2013
    86
    52
    72
    I have the same lathe and as far as I know the lead screw and feed rod are inter connected in the feed box so running one and not the other is not possible. If you want to disengage the feed box completely there is a neutral position on the feed direction control knob. Turning the knob so the arrow points up is the neutral position and will stop the lead screw and feed rod. My guess is that you already know this.
    If your gear box is making an excessive amount of noise it may be because it is set to feed the course threads. There is a feed knob on the outboard side of the headstock just below the spindle. If the knob is pulled out it is set to cut 14 TPI or courser. If it is pushed in it will be set to cut finer then 14TPI plus your normal feed rates for turning. If the feed selector knob is pulled out the gear box will really sing to you especially when you get to about 1000 RPMs. I don't know how familiar you are with this lathe so all of this might already be known to you.
    May 2005
    Interior British Columbia
    2,834
    329
    951
    I think you are probably out of luck.
    The feed uses the same gear train off the headstock (inside the LH end door) to transfer power from the headstock to the gearbox which runs the leadscrew and the feed rod. Note that the direction knob controls both.
    I think. Been a fair few years since I ran one.
    Aug 2012
    Bedford, IN
    997
    84
    304
    Quote Originally Posted by guest View Post
    I believe he wants the feed shaft to continue turning so he can continue doing auto-feed (either cross or longitude) but stop the lead-screw that would be used for threading.
    Quote Originally Posted by boomerang69 View Post
    I see them fine.
    Unfortunately, I don't see a way to disengage the lead-screw without also shutting off the feed-shaft. If there were a way it should be right there on the quick-change box. On my LeBlond Dual Drive there is a lever that just gets thrown between "FEED" and "THREAD". I believe there is also a neutral position on one of the 4 control levers to shut it all off.
    Sep 2009
    Virginia
    153
    30
    22
    thanks for the replies,I checked out some youtube videos and all that showed them running,the leadscrew was turning.Its not that big of a deal just when you change over to the course feed it gets a bit loud.I also thought if it could be disengaged it would save a little wear.Its been like it is this long i'll quit bitchen.Thanks again
    Sep 2009
    Virginia
    153
    30
    22
    Thanks for your reply guncrank,in the picture of the leadscrew I thought it looked like a repair where the shear pin is.I see on some of the others I looked at it looks the same.This came from the local high school,you never know if it was damaged and patched up.
    Jan 2013
    86
    52
    72
    Yeah I noticed that. I bought mine from a used machinery dealer so I have no idea of its history. Mine came with a roll pin in place of the shear pin. I have not bothered to change it in the 15+ years that I have used it.
    Dec 2010
    2,408
    39
    337
    I have quite a few lathes and over the years had many of the top brands. Simply put those lathes that change feed and lead screw connection do it after the quick change box. The quick change box is used to change both feed and lead screw rate. So if the gearbox is noisy and the lead screw was disconnected you will still get the noise. Only lathes I had or seen were old flat belt lathes that had a belt to run the feed. On those you could have one, the other or both. Probably why it's noisy is due to what looks like a repair. Someone could have crashed while threading.
  11. #11
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,343
    3298
    2094
    Previous operator of my SM lathe used a screw to replace tapered pin on the lead screw, in the drawer of tooling was the box of factory supplied taper pins, I'm guessing he was not real bright.
  12. Likes guncrank liked this post
  13. #12
    Sep 2006
    Sacramento County, California
    4,396
    2821
    1724
    Quote Originally Posted by guncrank View Post
    You might consider changing the roll pin to a piece of aluminum welding rod. I've accidentally crashed my 13X40 lathe now and then. The aluminum rod always shears with no damages. Had there been a roll pin, I'm sure that there would have been some broken gears.
    The aluminum rods that came as spares with my lathe were two mm. I use 1/8" aluminum welding rod scraped and sanded down to fit.
    Just a suggestion. It could save you a lot of trouble.
  14. Likes guncrank liked this post
