Parts availability NIL basically. Please read forum discussion guide lines/rules. Hone shop machines are not to be discuss on this forum. You might see if Grizzly sells a similar lathe if so you maybe able to get parts from them. If you know very little about lathes try to find someone local to give you some basic instruction. It is always better to buy a fully functional machine to start with if you do not know how to check out or repair same. good luck.
