Starrett combination square
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Dec 2019
    Florida
    13
    5
    Default Starrett combination square
    The vial level on my old combination square is broken. How do I get the screw holding it in place out, and where do I get a replacement vial? I appreciate any help. The original was glass. I also need a source for the scriber as well as the level vial. Thanks!
    Jul 2006
    rochester, ny
    2,015
    441
    590
    From Starrett?
    Jun 2006
    Spokane, WA
    659
    152
    Since new Starrett are so expensive, when I'd see a level or square with a broken vial, I'd pick it up for a buck or two. The intention was to repair several at once. Much as I hate to admit defeat, they're all still in the junk box.
    Turns out, sending them to Starrett Repair Service is barely cost-effective against the price of a used unit. Buying the vial and repairing them oneself is only a good deal if one enjoys a challenging hobby. Takes hours of time and care to do it right.
    jack vines
  4. Likes spotcheem liked this post
    Jun 2012
    Michigan
    5,204
    4783
    3150
    Quote Originally Posted by spotcheem View Post
    Are you sure it's a screw and not a pressed in plug?
  6. Likes Mike1974 liked this post
  7. #5
    Nov 2014
    Florida
    4,536
    1741
    2173
    Quote Originally Posted by Mtndew View Post
    Looking at my 80's vintage Starret combo squares (6" + 12"), it does appear to be a plug like maybe the vial is slightly pressed in? Or maybe the plug is just covering a set screw, dunno...
  8. #6
    Nov 2009
    Massachusetts
    450
    148
    I'd certainly ask Starrett how best to proceed. I've found them to be helpful for repair parts et al.
  9. #7
    Mar 2020
    New Jersey
    22
    27
    7
    I have replaced vials in carpenter levels but not in a combination square. I inherited Starrett combination squares. I'm a retired carpenter and used combination squares often. I do not recall ever using the level vial or the scriber. Try a scriber from a piece of junk square , probably will work.
    When I replaced the vial in a Hybridge level I set it in Plaster of Paris.
    Usually not worth the effort but this is a top quality level. Took 2 hours before I got the vial in and set in Plaster of Paris.
  10. Likes spotcheem, M.B. Naegle liked this post
  11. #8
    Dec 2019
    Florida
    13
    5
    Yes, from Starrett, but it's probably 50 years old. Maybe I can add a photo...
  12. #9
    Dec 2019
    Florida
    13
    5
    Quote Originally Posted by richard newman View Post
    From Starrett?
    yes, Starrett.
  13. #10
    Dec 2019
    Florida
    13
    5
    I donít know how to post photos, anyone know how? And is posting photos allowed?
    Iím kind of new to this forum.
    There is a screw or plug at the base with a slot. But I donít know if it is a screw or just a pressed in plug. Wish I knew how to post photos....
    I did contact Starrett a while ago and they do repairs. Expensive! I just thought if I could get the screw out, and find a vial, I could do it myself for the satisfaction.
  14. #11
    May 2006
    Seattle
    2,121
    50
    427
    I have a few Starrett combination squares. And I have ordered replacement scribers. Each one has been a bit too small. I need a way to very slightly increase the apparent size of the scribers (by definition harder than the gates of Hades). Ideas?
  15. #12
    Dec 2019
    Florida
    13
    5
    What is your procedure to calibrate the level vial once you put it in , to the edge of the square? And then how do you maintain its position while you put in plaster of paris? seems tricky?!
  16. #13
    Sep 2004
    south SF Bay area, California
    2,065
    158
    686
    Spotcheem --
    Bent-glass vials are commonly, if not usually, bedded in plaster (or today, RTV). The plaster or RTV is put in place first, and then the vial is pushed into the bedding. The vial is adjusted by pushing the high end deeper into its bedding compound. As you might suspect, such adjustments are highly iterative.
    In a production environment, vial adjustments were usually done with the stock, or body, of the level instrument on a known-to-be-level surface.
    John
  17. Likes spotcheem liked this post
  18. #14
    Dec 2019
    Florida
    13
    5
    Most have a brass sleeve in the hole where the scriber goes. Either replace the worn out sleeve, or add a new brass shim stock sleeve.
  19. #15
    Sep 2006
    SE PA, Philly
    5,523
    1074
    1978
    Quote Originally Posted by John Garner View Post
    In a production environment, vial adjustments were usually done with the stock, or body, of the level instrument on a known-to-be-level surface.John
    I found this info useful. IMHO, plaster is a little bit easier to replace I think - hard to scrape broken glass and cured RTV out of a small hole if the vial breaks again. BTW, in a nonproduction environment you can do what is called "bucking the level". Get a surface that's pretty close to level. Don't bother leveling it unless that's really easy. But you can test a new vial in wet plaster using the surface. Note how far out of level it indicates. Then reverse the level and compare. Adjust to cut the difference in half. Switch the level back and check. For the level in a combisquare, though, it may just be easier to level your surface plate with wedges or some such (bucking is often done with the ultraprecision levels).
  20. #16
    Dec 2019
    Florida
    13
    5
    Quote Originally Posted by bosleyjr View Post
    Still donít know how to get the screw/ plug out.
    Still donít know where to buy a replacement vial level.
    Still donít know how to post photos.
    Help!
  21. #17
    Feb 2011
    2,495
    1998
    1103
    I have replaced a few broken or missing vials, but they were all on (IMO) low accuracy tools like combination square heads, so i wasn't too concerned about how precise they seated. If the bubble was reasonably centered when it sat on a level surface, I was happy. One was an old Starrett that was missing the vial. It may have had a plug originally, but I just packed the end with plaster-of-paris much like John Garner described since the other combination square I was fixing at the time (a Miller Falls) was done that way.
    IMO the design of how the vial is held says a lot for how much accuracy you can expect from it. If the vial is directly adhered to the frame of the tool, it's for reference alone. If the vial has some means of mechanical adjustment or is in a separate tube attached to the tool, then you can worry about how many tenths it will read to.
    One I still need to fix is a Brown and Sharpe combination square. It has an aluminum plug in the end and when I get to it, my plan is to drill it out and turn a new plug to take it's place. It's old vial was set in some kind of rubber'y material like RTV. I don't think what you use is quite as important as long as it dries solid and provides a pastel background to make the bubble more visible. Plaster is easy to use and cleans easily when dry if it seeps out around the viewing area.
    As far as where to get the vials, most of mine were new-old-stock on Ebay. I've been known to scavenge them out of trashed tools as well. For general reference use, all you need to worry about is that the length and diameter match the hole you want to set it in.
  22. #18
    Nov 2003
    5,423
    188
    1810
    Posting images? Here you go.
    Using This Board's Image Hosting
    I don’t know how to post photos, anyone know how? And is posting photos allowed?
    I’m kind of new to this forum.
    There is a screw or plug at the base with a slot. But I don’t know if it is a screw or just a pressed in plug. Wish I knew how to post photos....
  23. Likes spotcheem liked this post
  24. #19
    Aug 2006
    Virginia
    618
    886
    357
    Happened to see a video from “How Its Made” with regard to Starrett combo squares. The cover for the vial is a metal plug that is pressed into the bore. A drill and pry procedure will probably work.
    Joe
  25. Likes richard newman liked this post
  26. #20
    Jul 2006
    rochester, ny
    2,015
    441
    590
    Interesting video
    YouTube
  27. Likes crzypete, Joe Rogers liked this post
