dazz
Stainless
- Aug 20, 2006
- New Zealand
Hi
The application is a miniature 1/3 scale model of a 1925 Steam Lorry that I plan to build. It has a 2 cylinder compound steam engine. The cylinders and pistons in the original were cast iron.
Traditionally model steam engines are CI, gun metal or brass. If I go to the model engineering forums, that is what I will be told.
The question I have for this forum relates to materials selection and compatibility.
I want to use cast stainless steel because:
The major disadvantage I know of is the willingness of SS to gall and scour. To reduce this risk, I propose to use carbon PTFE rings with a soft metal piston (eg brass).
To reduce the risk of cylinder galling, I would like to look at options around passivizing/coating the SS cylinder walls (eg.nitriding).
I have outlined what I propose, but is there a better solution?
Below is a photograph of the steam wagon on the wharf in the UK, prior to loading and shipping to New Zealand. Also, the original factory drawing of the engine.
Dazz
- it won't corrode,
- it is a poor thermal conductor (makes for more efficient engine) and,
- the local foundry can cast it.
Dazz
