badwithusernames
- Sep 24, 2017
I'm replacing several propane components on my forklift, and need several new hose assemblies made. For whatever reason, the local supply doesn't have 7132 propane spec hose. It seems that stainless braided PTFE would be a suitable substitute, if not overkill.. but they will not say and I do not know. Maybe one of you can give me some guidance please?
FWIW, one hose is between the first tank/ bulkhead regulator and the lockout filter, it is 3/8" hose with AN-6 one each end. The second is from the vaporizer and is 5/8" hose with AN-8 on each end.
Thanks in advance.
SD
Thanks in advance.
SD
