Themanualguy
- Aug 14, 2014
- Wollongong, Australia
This thread isn’t so much about helping me understand this, but more to I guess put it out there to fellow people who would probably be the last on earth to actually care about this. It might start some interesting conversation.
So about 1.5 years ago, I was working in a roll grinding shop at my local steelworks. I was working in the heavy roll assembly and stripping bay, mainly doing bearing chock maintenance of the large Babbitt bearing bushes for the mill backup rolls, and also dabbled in the roll grinding from time to time.
The building, built in 1955 and some 300 meters long (900 feet approx) was originally one of 10 machine shops in our steelworks, which employed 367 people at its peak in this “plate and strip mill machine shop” alone.
It was in addition to the;
No. 1 machine shop - still operating under a private company but it is running into the ground.
No. 2 machine shop - Long gone
Tin mill machine shop - long gone, this is now my workshop at my casual day job where I am the only fitter and Machinist with a bunch of boilermakers. I still have an Asquith OD1 radial and a Russian lathe and a few other radial drills etc.
Plate mill machine shop - now only roll grinders
Apprentice machine shop - long gone
Cold and temper mill roll shop - long gone
Coating and galvanising Machine Shop - recently closed
Coating and galvanising roll Shop - still operating
Materials testing machine shop - still operating
The PSM shop prior to 1988 handled ALL the repairs and machining work for that department, same as how the other machine shops maintained their own departments. 1988 the order came down that all machine tools are to be removed from the PSM machine shop, leaving only an Asquith OD1 radial drill, the 2 biggest Craven lathes for ancillary roll turning work and 1 of the old manual Farrel roll grinders (1.6 meter swing, 10 meter centres). From my research some 30 years after this happened, I found this was a serious shop, Giddings and Lewis Floor Borer, Scheiss vertical borers, 4” spindle Richards borers, 12 lathes, shapers and slotters, a vertical spindle Niles grinder, 9 roll grinders ranging from small to large, the biggest slotter in the area ( a large Ravensburge) and some cincinatti mills. The boys tried to keep a small 60” centres Lang lathe, but management said no. That Lang lathe eventually found its way back years later, and I witnessed it loaded on a truck in 2017 destined for the steelmaking Shop where it would be tipped into the furnace as scrap. In fairness that Lang was only good for the furnace anyway.
Fast forward to 2018, I began to mention the concept of installing some machining equipment to do repairs in house, as it was getting quite costly sending every job out and waiting for the parts to return (sometimes we wouldn’t have bearing chocks finished due to missing parts still out being repaired at outside contract machine shops, and we had to do “hot changeovers” of the bearing chocks straight out of the rolling mill straight onto freshly ground rolls).
We had an opportunity to Aquire some machines from the recently closed down Coating and Galvanising machine shop. I went all giddy eyed and got excited about what we might find in there. The management of that machine shop said to take anything we wanted.
We toured the shop. Kearns and Richards 4” borer, Webster and Bennett 48” vertical borer, 3 large VDF Boeringer lathes, Kellenburger cylindrical Grinder, Colchester and mazak small lathes, Huron Bed Mill, large surface grinder, 400 ton horizontal press, another Asquith OD1 radial, Fromag keyseater, and of course all machines had lockers full of tooling.
I wanted it all, we had room to spare at the roll shop, and I had jobs I could do on every one of those machines. But I guess I let myself get a little carried away.
Management of my shop said 3 small machines only, no borers and no presses or surface grinders.
I picked my 3
- Huron Bed Mill PU77
- VDF Long bed lathe (120” centres)
- Bandsaw
We booked a date to go and remove the machines
Management changed their mind. Now only 1 machine allowed.
I wanted the Huron Bed Mill, as we already had a victor lathe at my shop that I brought over from my old department (I wish now I had just put it on a truck and taken it home on a 6am shift change when no one was around)
We attempted to remove the Huron, but it was grouted into the floor, management said no you won’t jack hammer the grout away, forget about the mill and leave it.
We came away with nothing (not entirely, I did rather well out of INT50 toolholders for my cincinatti mill).
That my friends is the story of how someone declines the offer of a free, fully functional machine shop.
Corruption, union issues and I guess the desire to remove any liabilities from their operations is what brought about the closure of the coating and galvanising machine shop in 2017, and as far as I know, those machines are all still in that shop today with clear plastic over the ways and beds, collecting dust and dirt as the remaining two boilermakers dwindle down their last days before retirement. The remaining machinists that were sacked have long gone.
I’d love to hear similar stories as it just completely baffled me, the entire process.
I picked my 3
- Bandsaw
