Fish On
Hot Rolled
- Feb 23, 2014
- Foley, Alabama
I need to make rubber washers (just a spacer) with a 2" ID, 2 5/8" OD. I've been using .063" neoprene, 50 or 60 durometer.
A few years ago, I made a little cutter out of 2 sizes of thinwall steel tube, sharpened and welded to a plate. Would press onto a piece of 1/2" UHMW, in a bottle jack style hydraulic press. Worked well enough, but not well, and the "die" would wear out frequently needing resharpening.
Recently, it went from well enough, to not working at all - thinking McMaster may have sent me the wrong rubber durometer, but buying the next harder one didn't help.
I need to get a better method for these. Looks like steel rule die is the answer, as long as I can press them on something I own (annual required qty doesn't justify spending a lot to buy a clicker press).
Ideally, I'd hit these things 1 at a time on a Diacro #2 punch (4 ton punch). With about 14 1/2" of steel rule, does 4 tons seem feasible?
