JasonPAtkins
Hot Rolled
- Sep 30, 2010
- Guinea-Bissau, West Africa
I should probably be posting this on weldingweb, but I'm assuming machinists are more likely to notice small variations, haha. Here in West Africa I have a ton of trouble getting material that's correct to the name. Sheet metal isn't gauged, it's called out by the mm of thickness. When we buy 1.0mm sheet, it's 0.7mm, if we buy 1.2mm it's actually 0.9mm, etc. I'm pretty sure that's just the resellers playing games (importing .7 and calling it 1.0) because I don't think the russian mill that's producing it can't tell the difference between .7mm and 1.0mm. We just compensate by buying the next size bigger to get what we actually wanted.
However, I've had a ton of trouble finding strong 25mm x 25mm square tube. This week I finally went to the regional distributor for West Africa with a mic, and even there what they're selling at 25mm x 25mm x 1.50mm wall actually mics at 1.35mm. Is this common in metric structurals? I've spent much less of my metal-consuming life back in the States, but when you buy 16 gauge tube, I'm assuming the stock tolerance isn't so wide that they could get away with giving you 18 ga, which is pretty much what's happening to me?
I'm working on a small factory to produce chairs and desk from bent/welded tube, and the difference in stiffness and how quickly rust will get through the wall is very different between .9mm, 1.2mm, 1.35mm, and 1.5mm.
