Strange happenings in the heat on a machine.
Likes Likes:  0
Results 1 to 9 of 9
    Oct 2008
    Melbourne, Australia
    71
    19
    9
    Default Strange happenings in the heat on a machine.
    I thought this worthy of sharing amongst a knowledgable crowd like you lot:
    Here in Melbourne we are having a bit of a heat wave of 30-35DegC this week. I went to use my Feeler FTL-618-EM last night and found the saddle slide was very sticky when it normally feels like silk.
    Here is a pic of my machine.
    After a little mumble&^$##@$*&!mumble as to what the help was going on I worked out the oil viscosity had changed in the heat and was squeezing out of the turcite ways without maintaining a film thickness like it did in the colder weather.
    This simply means I had the main dovetail gib a little bit tight to start with but never picked up on that when the oil was filming properly in the cooler weather. So I backed it off a tad and we are back to normal silky smooth.
    Anyone else ever noticed strange happenings like this?
    Jul 2009
    Cobblers Knob, IN USA
    1,100
    6
    My stuff gets sticky when it gets below about -12 deg C
    But I just take that as God's hint and go inside where it's warm!
    Aug 2009
    AUSTRALIA
    526
    111
    72
    Yeah ive had something similar. With lots of roughing on a manual lathe and minimal coolant, the pile of blue swarf on the cross slide heats it up and makes it go tighter.
    Mar 2005
    Canberra, Australia
    592
    Does Turcite contain Teflon? I'm guessing it is a mixture of teflon and a harder plastic, as are most of the Rulon versions. Teflon has a high coefficient of expansion and in addition it undergoes a change in crystal structure at around 20 degrees C with a dimensional jump of about 1 1/2%. Possibly what you have is just enough expansion of the Turcite, sandwiched between the metal, to squeeze out the oil film.
    - Mike -
    Oct 2008
    71
    19
    9
    Knudsen: I suppose you try to turn on the coolant at that temperature too?? "dang its frozen up again... I just don't understand..." Its a wonder the machine doesn't have some sort of "humanity for the operator" cut out switch at about +5Degc, that would work for me.
    HelEx: I never thought of that, the stuff on my slides is a kinda light blue color, almost sky blue. I don't really know what it is but I am assuming turcite. There is only 1mm or so of layer on there, not enough to bother it, or so I would have thought. This is getting technical now but bring it on. Maybe I need a NATA certified climate controlled lab to keep the lathe in now... mmmmm that would be nice.
    Apr 2006
    Laytonsville, Maryland
    535
    14
    Turcite will have a significantly higher coefficient of thermal expansion due to the organic resin that is part of the composite. When it heats up, it is effectively tightening up the gib. An all-cast iron machine would not suffer that effect. Next winter, you will need to tighten the gib quite a bit.
    Feb 2005
    Nashville, TN
    27
    The oil isn't a multi grade automotive oil, 10w-40, is it?
    Oct 2008
    71
    19
    9
    Absolutely NOT! No multigrade crap goes near my machine slideways.
    Is slideway oil for me.
    Sometimes for other machine parts I use straight 30W, less of those additives and muck that will gum up the works down the track.
    Feb 2005
    Nashville, TN
    27
    Uh...Sorry. 10w-40 is the only thing I could think of the gets thicker when it gets hot.
