Strange issue with a 4' fluorescent light fixture
Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Nov 2007
    marysville ohio
    10,825
    3027
    7485
    Default Strange issue with a 4' fluorescent light fixture
    One fixture, 2 lamps side by side and end to end. 2 ballasts, one for each pair of bulbs. No starters. It worked fine for years. Now you turn the wall switch on and nothing happens. If you touch one of the bulbs that pair lights up instantly, then touch one of the other pair and it lights up instantly as well. Avery light touch will do it, I am not rotating the bulbs to get a better contact on the pins. WTF?
    Mar 2009
    Brunswick Oh USA
    4,813
    5732
    2926
    john,
    One of mine did the same thing. Maybe it's static el.
    Sep 2006
    Stillwater, Oklahoma
    1,939
    156
    1176
    Moonlight, you clearly have the magic touch. Look into hiring yourself out to fix all the other things that don't work.
  4. Likes 52 Ford, Bobw, mike44, johansen liked this post
    Feb 2007
    St. George, Utah
    1,494
    1000
    1040
    Not sure about other types, but most T5-HO lamps need a grounded reflector or other surface nearby to start reliably. Could you have lost the ground to the fixture?
  6. Likes garyphansen, DrHook, Winterfalke, JST, Modelman liked this post
  7. #5
    Jun 2004
    918
    910
    211
    time to retro fit led's in that fixture
  8. Likes Steven-Canada, DrHook, Flute Maker liked this post
  9. #6
    Oct 2005
    Wilmington DE USA
    2,402
    396
    538
    I have 2 4' doubles that have been doing it for a couple years
    Usually when it's cold
    Rub across the bulbs with my fingers and they're on.
    Glad I'm not the only one this happens to
    These 2 light sets are on the led replacement scedule
  10. #7
    May 2021
    Virginia
    346
    379
    89
    Quote Originally Posted by moonlight machine View Post
    Bend the contacts on the fixture to get better contact. Might be metal fatigue from heat cycles? Had it happen to one of my lights. Try LED bulbs, if you replace the florescent ones. No warm up and they don't need a ballast (and better CRI)
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  11. #8
    Nov 2007
    marysville ohio
    10,825
    3027
    7485
    Quote Originally Posted by 52 Ford View Post
    I was born at night, but not last night. I know how to correct the issue, replacement is no problem. Did the contact deal and replaced the tubes. same issue. I want to know why it is happening. How can they light up with the lightest touch.
  12. Likes DrHook, Dan from Oakland liked this post
  13. #9
    Jan 2002
    West Coast, USA
    9,349
    613
    6827
    Could be your fingers/body are adding capacitance, helping whatever not-quite-strong-enough starting voltage to ionize the gas in the tube.
    Somewhat different deal, but some capacitance switches will operate when a finger gets close; and not even touching.
  14. Likes 52 Ford, Rudd liked this post
  15. #10
    Oct 2005
    22,785
    Quote Originally Posted by TGTool View Post
    Yup, he's touched....
  16. Likes charlie gary, 4GSR, mjk liked this post
  17. #11
    Jun 2013
    Northern Il
    1,715
    879
    1581
    When you touch the tubes, you are adding capacitance to the circuit which does increase the current flow during part of the cycle and sort of triggers the tube start. If you had an electronic ballast, it is likely that you would not have this issue.
  18. #12
    Mar 2011
    Geneva Illinois USA
    6,662
    2991
    2678
    Its the low level of mercury now used in fluorescent tubes. Yes, it is the need of a ground plane but also higher strike voltages to establish the arc. Most likely you have magnetic ballasts that don't provide the really high voltage needed to strike the arc. If you want to continue with the fluorescents, change the ballasts to electronic. Better yet change to LED
    Tom
  19. #13
    Nov 2013
    Eastern Massachusetts, USA
    7,822
    6497
    6920
    Quote Originally Posted by Ray Behner View Post
    john,
    That's what I suspect. Fluorescent bulbs require a high starting voltage.
    Other possibility is that the pins or sockets are oxidized enough that touching the bulb micro-wipes the contacts enough to work.
    PS: I don't like LED bulbs for area lighting so I replaced several older ballasts with electronic.
    Fairly inexpensive on Amazon and make a world of difference.
  20. #14
    Sep 2005
    Oakland, CA
    3,131
    676
    1033
    I've got a few doing the same thing- and they have electronic ballasts. Replace the lamps, life is good, climb down, shut them off and then back on- nothing!
  21. #15
    Mar 2009
    6,611
    131
    1275
    You a capacitive kind of guy. If this thing happens every time then there is a saying in the business. "It's fixed".
    If you touch the tube with a eraser (insulator) and it lights then the issue is mechanical. If you touch with your
    hand then it's electrical. Would be interesting it you tried it with bare feet and see if the start time increases
    or decreases.
  22. #16
    Jul 2005
    Cottage Grove, MN 55016
    8,626
    4520
    5086
    I had 2- 8' fluorescent 2 bulb light fixtures start blinking and I replaced the bulbs as they were dark at the ends, that didn't do it. I bought 2 ballasts at an an auction for a bargain and replaced one. It was a real pain standing on a ladder reaching overhead. That didn't help. I finally went down to Home Depot and bought a $25.00 LED 4' single bulb light fixture, hung it up and bingo it worked. Someone suggested I buy 4 - 8' LED's bulbs to replace the old Fluorescent ones and wire direct. They would cost $175.00. No Thanks....I bought another cheap LED and I'm happy.
  23. #17
    Nov 2009
    Massachusetts
    830
    310
    I agree with the theory that the ballast (of whatever kind) is no longer providing a strong enough HV pulse to reliably strike the arcs in all tubes, even if the tubes are not new. When the pulse is only just sufficient, suddenly the phase of the moon matters.
  24. #18
    Jan 2007
    Flushing/Flint, Michigan
    11,121
    666
    8891
    Really weird is it not?
    Your touch on the outside of the bulb adds something that helps start the ignition, that tiny bit when unable to do it alone.
    Bob
  25. #19
    Feb 2007
    St. George, Utah
    1,494
    1000
    1040
    Nope. Not weird at all. As I said above, a lot of these fixtures require a significant ground-plane near the tube to start, and that's with an electronic ballast. This is possibly a variation of that.
  26. #20
    Mar 2009
    6,611
    131
    1275
    Would be interesting if you touched the surface after grounding your hand. Then do it again without the ground, you
    could even call your longest haired employee and run a comb through his hair to charge you up with excess electrons
    before the touch.
    In the past I have walked around the concrete floor with bare feet and turned on a machine here and there. I wouldn't
    exactly call it naked machining, but I have felt little tiny tingle sensations on my feet. All my electrical is wired
    correct the floor is not actual ground.
    Advice from a LED bulb owner:
    I bought 8 footers about a year ago. Removed those failing ballasts and simply connected a couple of wires. No regret.
