We have had some issues with scratches in a black oxide surface on the inside of a steel tube. Swedish prime quality steel. During investigation we discovered a very strange phenomenon at the bottom of some of the scratches. See attached picture. It's a pattern consisting of perfect rows of dots/holes with a spacing of approximately 8 microns in both axes. One pattern is 15x15 dots and the other 13x9. According to the laboratory these may be imprints from some kind of tooling or measuring equipment. This may be the wrong forum for this question, but maybe someone has seen something similar.
Thanks for the replies in the first, and now closed, thread!
Some more facts:
- Forged Ovako steel blanks. Steel produced in Sweden and forged in the UK.
- We machine the blanks and the inside surface is grinded to Ra 0,4 and then shot blasted (glass GL 4) prior to black oxidation. Then oil is applied.
- No laser machining on the inside of the tube, which is where the phenomenon is found. The outside is laser cleaned for improved adherence to the forthcoming
composite winding.
And by the way:
I’ve started a couple of threads in this forum to try to get some help regarding issues that I’ve encountered. All the time some of the replies imply that my description lacks data or that the pictures uploaded are bad. This time the moderator even closed the thread due to “meaningless topic title”. Why don’t you just be a bit more tolerant. I think that I give you all info I have at the time of starting the thread and expect you to ask questions or tell me to be more specific in the topic title. I realized (a bit too late) that the pictures in the original post was a bit small and intended to fix that. I didn't realize that the topic must be foolproof to be accepted by the administration of this site. You are all a bit like bullies! I’m Swedish and I try my best to get answers from you, but maybe I’m not as great at writing in English or American or whatever you folks understand. Sorry! Humorous comments like "Was that metal from Rockwell?" are, however, most appreciated.
By the way (part 2):
I have received great response in earlier threads from some people, which helped me a lot in the ongoing investigation. Thank you all for that! That time it was regarding Ti6Al4V. Now it is forged steel.
Some more facts:
composite winding.
And by the way:
