Hi again all.
This is a simple problem the solution to which I've pondered since I got employed at my current job.
I run a 3-axis mill. Normally speaking I have access to four vises. Also some chucks etc. It's a Doosan Mynx 750/50.
The workspace size is roughly 1500mm X * 750mm Y * 850mm Z. I feel that I rarely if ever make full use of the space.
I want to optimize this mill for mass production with a generalized fixture system. It should be able to handle both small and big workpieces. I need to be able to make this myself from material in the shop - aluminum, steel, brass, stainless, etc.
I have had many different ideas for this but I've yet to come to the point where I feel "fine, let's do this." So I'm putting the question to the community for opinions without venturing my possible solutions just yet.
It's fine if you suggest expensive fixture systems that I could just buy, but my boss probably won't buy anything expensive, even tho we've had people demoing these for us.
Why do I care? Well, I like making fixtures.
This is probably the single most important question I am addressing at work right now, because I feel if done proper it could revolutionize my production, improve my workplace environment, reduce joint stress... all kinds of stuff.
Discuss?
Discuss?
