Hello. I am in need of some help identifying an old lathe. More specifically, I am trying to figure out what type of taper is used on the headstock.
It almost seems like a Morse taper #3 although it doesn’t seem quite right to me. I have a dead center that came with the lathe which fits correctly. I also have a reamer with a Morse taper #3 that seems to fit slightly different. When I try to release the reamer with the Morse taper by reversing the wheel on the headstock, the reamer with the Morse taper never bottoms out and it gets pushed out of the headstock like the dead center does. I noticed that the dead center sits deeper into the taper than the reamer does. See the pictures. I am marked the tools with white paint where they sit in the taper.
Help me out if you can please! I’d like to get a drill chuck that I can use in the headstock.
