Sunnen MBB 1600 sump
Results 1 to 19 of 19
    Mar 2013
    Cerritos, CA
    390
    129
    148
    Default Sunnen MBB 1600 sump
    Does this belong in a Sunnen MBB 1600 sump? It's been in there for years and I don't see that it does anything.img_2678.jpg
    Jan 2007
    Norfolk, UK
    19,029
    14529
    14628
    looks like a sediment trap / weir box to me.
  3. Likes sfriedberg, tdmidget, digger doug liked this post
    Mar 2013
    Cerritos, CA
    390
    129
    148
    I always considered it a sediment trap but I never saw a way the oil drained into it without modifying something, that's why I wonder if it belongs in there at all.
    Jan 2007
    Norfolk, UK
    19,029
    14529
    14628
    Some more pics of how it fits in the machine etc etc etc might help - we need detail.
    May 2003
    4,666
    355
    It is a sediment trap, and it goes under the "drain pipe" for the tray. My MBB 1600 EMS has the same part. The pipe may be missing from the tray to the tank.The 1600 is the last all cast iron standard horizontal hone, and has a nifty speed system.
    Mar 2013
    Cerritos, CA
    390
    129
    148
    I always thought the "drain pipe" should empty into the sediment trap in question but my drain pipe goes from the tray to an elbow to another pipe straight down to an inch or two from the bottom of the tank. The sediment trap will not fit under this long drain pipe unless maybe it didn't go straight down and I rotated or shortened it.
    Jan 2007
    Norfolk, UK
    19,029
    14529
    14628
    MMMMMMMMMMMMMMMMMMMMM???????? sounds to me like - one way or another that drain pipe has to discharge in to that sediment box.
    FWIW ;- IME coolant discharge & drain pipes that go below the level of the ''catch pond'' are bad news as air locks can occur.
  9. #8
    May 2007
    238
    9
    26
    It belongs there the design has worked well for 50 years.
  10. #9
    May 2009
    Canandaigua, NY, USA
    2,898
    141
    1293
    Can the pipe be rotated up on its threads to get the thing under it?
  11. #10
    May 2003
    4,666
    355
    Quote Originally Posted by Conrad Hoffman View Post
    That's it! I took a look at mine, the pipe is loose enough that it can be swung to the side, and the trap slid in or out. It is probably a good idea to use it, mine had a lot of swarf in it.
  12. Likes Limy Sami liked this post
  13. #11
    Mar 2013
    Cerritos, CA
    390
    129
    148
    Exactly the answer I hoped for!
  14. Likes Limy Sami liked this post
  15. #12
    Sep 2007
    mesa arizona
    538
    84
    I decided to clean our main sump one time and it weighed a ton. It seems the lathe man threw all his bad parts in there thinking no one in their right mind would ever look in that tank.
  16. #13
    Jan 2012
    Southwest
    1,103
    115
    290
    I hope this doesn't count as hijacking the thread, but does anyone know what the three letter code after the model number designates? In my case the code is JIC.
  17. #14
    May 2007
    238
    9
    26
    Quote Originally Posted by opscimc View Post
    It stands for "Joint Industrial Council". It is electrical standards set up by machine tool builders for building machine tools. Your machine will conform to the standard in place when it was built.
  18. Likes opscimc liked this post
  19. #15
    Jan 2012
    Southwest
    1,103
    115
    290
    Quote Originally Posted by gappmast View Post
    Thanks very much for that. Since it is part of the serial number I thought it must be a code for the specific configuration or options that were part of the machine when it left the factory. Not unlike how the three places in a, say, 'J57' stone denote the specific properties of that stone.
  20. #16
    May 2003
    4,666
    355
    Quote Originally Posted by split tenth View Post
    Find the same in my tank, I am running low on oil!
  21. #17
    May 2007
    238
    9
    26
    Quote Originally Posted by donie View Post
    Sometimes operators will put stuff in the tank to raise the oil level when they run low. When they order more oil they tend to forget to remove it.
  22. Likes sfriedberg liked this post
  23. #18
    Mar 2006
    jacksonville,fl.
    1,150
    971
    386
    Jic also is a standard for hydraulic fittings,probably the most popular type in the US.
  24. #19
    Oct 2002
    woodland wa clark
    956
    20
    You should have two a small one that one drains into Ken
    L
