zr1nsx
- Dec 31, 2007
- indianapolis
Would anyone have a operator manual for the power stroke unit for a MBB 1680 honing machine? I acquired a nice used machine with power stroking but have never used a power stroking hone. I don't really need the power stroking for the projects I have, but would like to know how the unit works and how to set it up. I guess I should clarify a little. The set up of the stroke and speed seems simple enough. I have had the machine stroking before, but don't know how I got it to start. Not sure if there is a limit switch engaged that is keeping it from working, or if I just have not done something correctly. It worked when we first powered the machine up, but now I can't make it cycle. The manual portion of honing works fine and I use the machine fairly often. Would like to get this thing solved, and Sunnen has no data on the power stroke option for this machine.
