I am working on my Boyar Schultz surface grinder. The spindle bearings are a normal ball bearing at the nose, and a smaller angular contact at the rear with a sprung spacer setting the prelude on the angular contact. Both bearings are Barden.
Is there a technical reason for using the radial bearing at the nose vs two angular contact bearings? Do angular contacts only function properly if they are the same size? Was it a cost saving measure?
