HoneyGrids
- Sep 17, 2011
- Hickory, NC, USA
We need angle brackets to attach extruded 45° mitered channels together (similar to a picture frame).
We will either make custom angle brackets (shearing, punching, and braking) or buy a used surface grinder and modify off-the-shelf angle brackets. Modifying the off-the-shelf brackets involves surface grinding 3/32" off both sides so the 5/8" wide bracket will fit into the 7/16" channel. The thickness of the bracket is 3/32", so there isn't much metal to be magnetized. I attached a drawing of the angle bracket. My question is, can it be done, and/or is it more trouble than it is worth?
If we had it, I'm sure we would use the surface grinder for other projects in the future.
Any insight is much appreciated!
